5.7 hemi into 07 Dakota
#2264448
03/06/17 06:52 PM
03/06/17 06:52 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
So are there any motor mounts out there or am I gonna have to make some for my 4x4?
Also for the throttle body what is everyone doing? My 4.7 has a cable but the 5.7 is drive by wire. Is there a big manual throttle body that will work with the 4.7 computer or do I got to use the 4.7 TB or what? If I go to switching computers then I got to wory about VIN, security and miles programming...
Everyone says its real easy but having a hard time finding anyone that followed this through to completion.
Re: 5.7 hemi into 07 Dakota
[Re: cudaman1969]
#2276192
03/25/17 10:01 PM
03/25/17 10:01 PM
Posts: 7,664 IN
ahy
IN
Aren't the Dakotas the same as the Durangos under the hood and same frame? 1'st generation Durangos were based on the Dakota. They never had the Hemi. 2'nd generation Durango's (~2006) did have the Hemi and were different underneath I believe. Still worth checking as 2'nd generation Durangos also had the 4.7.
[Re: HotRodDave]
#2276671
03/26/17 06:56 PM
03/26/17 06:56 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Everyone says its real easy but having a hard time finding anyone that followed this through to completion. Also try DakotaDurango.com under the engine specific thread. "5.7 Hemi "
[Re: HotRodDave]
#2276822
03/26/17 11:14 PM
03/26/17 11:14 PM
HotRodDave
Kalispell Mt.
its a 4wd and the front diff bolts on different on the 04 hemi durango sitting in here.
[Re: HotRodDave]
#2277173
03/27/17 02:43 PM
03/27/17 02:43 PM
HotRodDave
Kalispell Mt.
I am not looking right now but one the bracket bolts to the top of the diff front to back and the other bolts to the top of the diff side to side. My interchange says 01 to 11 dakota front diff interchange and only 01-03 durango will go in the 01 to 11 dakota. For some reason when they changed the durango body in 04 they decided they should change the way the front diff mounts.
