A518 build for a 400hp early hemi
#2274270
03/22/17 03:35 PM
03/22/17 03:35 PM
Posts: 19 Colorado springs, CO
Arominus
First post here, i'm active on Forwardlook, jalopy journal and few other off topic sites so not new to the forum game. My current project is a 1957 desoto and I'm building up a 58 392 for it. .030 over bore w/ 10:1 hypereutetic pistons, a howards cams .470/221/110 cam, some mild porting (mostly exhaust side), a hot heads aluminum dual plane intake and a holley 750 vac secondary carb. So with that out of the way heres my questions. Looking at 450ft/lbs from 2000rpm and 400hp@ 5000rpm I picked up a 46RH out of a 1995 Ram van 5.2L 2wd yesterday, it had 134k on the clock and the fluid was a little dark but not burnt, no metal in it. I'm thinking I can get away with not going through the entire thing but i'm going to do some upgrades to help it live. The converter will be the stock lockup for now, since it came off the 318 its the correct balance for my motor already. Ill jump to a hughes 2000 stall down the road. Heres my list From Cope racing: 4.2 ratio band lever HD Band strut and band foot TF-2 shift kit. 5600rpm shift governor From A&A Push button shifter cable (lets me use the 50's push button shifter) http://www.aandatrans.com/Products/Push-...le__AACCPE.aspxFrom HGM Compushift mini for the 518 w/ a TPS to control lockup and OD. https://www.hgmelectronics.com/products-compushift-controllers/csm-chryslerWhat else should i be looking at in the front case? i'm trying to avoid touching the OD unit unless i absolutely have to.
1957 Desoto Firesweep 2dr 392/A518 builds in progress.
Re: A518 build for a 400hp early hemi
[Re: Arominus]
#2274399
03/22/17 06:59 PM
03/22/17 06:59 PM
Posts: 3,089 Michigan
A727Tflite
Take the overdrive apart and just look it over. At that mileage you may catch things getting ready to fail. Just behind the OD clutch you will find a wavy snap ring setting against the flat snap ring. Replace that wavy snap ring - very high failure rate. The OD clutch is the first clutch you see when you pull the OD unit off the trans. All the needle bearings - check them all real good especiallly the one on top of the unit when you pull the OD from the trans. Make sure you do not drop that bearing - you will fracture the race and it will fail later. There also is a thick shim under that bearing that sets on the OD piston. Make sure you don't lose that. Keep everything in order as you take it apart and you should have no problems putting it back together. The only other item that takes a hit is the small and large bushings in the output shaft. Check those out reall good too.
Save your money - you don't need anything more than a 3.8 lever and the standard strut and anchor are more than adequate for even a race trans. The 318 converter will probably stall in the high 2's low 3's with that torque.
[Re: A727Tflite]
#2274790
03/23/17 01:57 PM
03/23/17 01:57 PM
Arominus
Save your money - you don't need anything more than a 3.8 lever and the standard strut and anchor are more than adequate for even a race trans. The 318 converter will probably stall in the high 2's low 3's with that torque. Should i just be looking at doing the clutches then if i'm going in? or does that require dealing with that 800lb spring? If its not a big deal, i can swing doing the clutches in the entire thing. I'm probably better off doing that... thanks for the suggestion on the Torque converter, ill look into the reman mopar converter.
[Re: Arominus]
#2274807
03/23/17 02:45 PM
03/23/17 02:45 PM
A727Tflite
To take the whole OD unit apart you have to compress the spring. A regular shop press is more than adequate. You can make a tool if you don't have the correct unit. A piece of pipe is fine and it doesn't have to be too tall. Pilot on that bearing/shim seat of the direct clutch sleeve. There is a safety ring inside that once compressed you remove then remove the snap ring and clutches for the direct clutch then slowly release the direct sleeve/hub. If you hit a brick wall PM me and I can walk you through it. Just keep things in order. Even better is have someone video you as you take it apart 😀 The direct clutch usually does not need replacing as it is always on until 4th and it is not affected but any fluid issues. The OD on the other hand sees a lot of use and is controlled by fluid pressure.
[Re: Arominus]
#2274995
03/23/17 08:33 PM
03/23/17 08:33 PM
Arominus
I can set the gopro up and film when i get there Thank you for the info, ill follow up more when i'm getting into the trans.
[Re: A727Tflite]
#2277918
03/28/17 07:25 PM
03/28/17 07:25 PM
Arominus
To take the whole OD unit apart you have to compress the spring. A regular shop press is more than adequate. You can make a tool if you don't have the correct unit. A piece of pipe is fine and it doesn't have to be too tall. Pilot on that bearing/shim seat of the direct clutch sleeve. There is a safety ring inside that once compressed you remove then remove the snap ring and clutches for the direct clutch then slowly release the direct sleeve/hub. If you hit a brick wall PM me and I can walk you through it. Just keep things in order. Even better is have someone video you as you take it apart 😀 The direct clutch usually does not need replacing as it is always on until 4th and it is not affected but any fluid issues. The OD on the other hand sees a lot of use and is controlled by fluid pressure. Where should i order a rebuild kit for this trans in your opinion? I think i'm just going to go through it and not worry about it once its in.
[Re: Arominus]
#2277994
03/28/17 09:09 PM
03/28/17 09:09 PM
A727Tflite
Check the price of a Mopar Banner or Master kit against a local trans supplier that handles Transtar parts. Both quality kits, the Mopar kit is likely higher in price but it has the good stuff and ALL the stuff you need.
There are three Mopar kits, one with seals and gaskets only, 2nd kit has the seals and gaskets and frictions, the last has all plus the steels. Front band included. usually the rear band does not need replacement.
Maybe you have a Chrysler retiree or friend - if so they can get a 25% discount off list price -
[Re: Arominus]
#2279088
03/30/17 08:44 PM
03/30/17 08:44 PM
Posts: 43 League City, TX
BlueGhost
League City, TX
Nice project, I'm looking at doing something similar with my 58 Plymouth. I have a 440 and am undecided between a 4l60e or 518.
Do you have a way to park it? You will either need to figure out a way to shift into park, or update your rear axle to have a parking brake.
1958 Plymouth Suburban
[Re: BlueGhost]
#2279295
03/31/17 01:10 AM
03/31/17 01:10 AM
Posts: 200 Colorado
Bob J
Colorado
Go to a C body axle or just upgrade the brakes 11 inch drums or disc with E brake. The brakes on your 58 are not the best at stopping a stock car now add 400+HP.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: Arominus]
#2279722
03/31/17 05:58 PM
03/31/17 05:58 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Poor lubrication to the O/D unit often causes the dark fluid - a result of not enough fluid volume through the intermediate shaft to the O/D unit. This was the root cause of many A518 failures - not enough coolant flow to the O/D planetary set would over-heat the fluid. I'd look into an up-graded intermediate shaft that has larger coolant holes.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Arominus]
#2281826
04/03/17 08:47 PM
04/03/17 08:47 PM
Evil Spirit
Newport, Mi
Yeah, not going to argue that crappy fluid causes a lot of issues - for the most part, most trans fluids are actually hydraulic fluids, and some have friction modifiers, but for the most part are poor lubricants. I've added a qt of 30W non-detergent to most of my builds for about 20 years to help lube the planetaries, bushings, etc. Some may dis-agree with this practice, but it has never caused an issue for us, and inspections of transmissions that we have used the oil in always show perfect wear items. As to the intermediate shaft, I'm pretty sure it was a re-builders tip, but starting about '92 or so we usually drilled out stock shafts (PITA) until the upgraded ones came available. Once we started using the modified intermediate shafts and the qt of oil, we did 100+ units with pretty much nil comebacks.
Kinda funny that it took the factory from '88 to '98 to fix the issue by changing the fluid - sharp re-builders had cured the problem long before.
[Re: BlueGhost]
#2282416
04/04/17 08:08 PM
04/04/17 08:08 PM
Arominus
I'm still on the fence, i may be brave and just do the push button shift with the 60's axle we have. Thing is the E-brake pull on the FL cars doesn't really have a "safety". It can pop off if bumped and that kinda sucks. I'm leaning towards a floor shifter to get the park function out of the 518, as cool as the buttons are, having the car roll away would suck.
[Re: Handygun]
#2282418
04/04/17 08:10 PM
04/04/17 08:10 PM
Arominus
have a 392/518 in my 58 Plymouth. Pat @ A&A did the trans and it works great. The car has 4.10's in it and the o/d unit has been flawless so far in wide open 3-"4" shifts and where I stayed in it in o/d under wide open blasts. The shaft with the oil holes for o'd lube were opened up to 3/16 for increased oiling. Mine is a one wire, I have a push/pull off/on button where the shift quadrant was and a floor shift. The o/d unit fits in the recess for the parking drum like a glove on my car. Excellent, i was thinking there would be plenty of room for the OD unit since the OE trans had that parking drum hanging off the trans. You have a picture of the trans crossmember mods that were needed by chance?
[Re: Arominus]
#2282497
04/04/17 10:12 PM
04/04/17 10:12 PM
BlueGhost
League City, TX
I'm still on the fence, i may be brave and just do the push button shift with the 60's axle we have. Thing is the E-brake pull on the FL cars doesn't really have a "safety". It can pop off if bumped and that kinda sucks. I'm leaning towards a floor shifter to get the park function out of the 518, as cool as the buttons are, having the car roll away would suck. With the push button shifter in reverse, there is still some travel left in the cable mechanism. I've wondered if a second cable attached to a lever under the dash could be used pull/push the cable on the shifter/trans into the park position. Something that when released would give the shifter enough slack to operate normally.
[Re: BlueGhost]
#2282728
04/05/17 11:08 AM
04/05/17 11:08 AM
Posts: 19,499 north of coder
moparx
I'm still on the fence, i may be brave and just do the push button shift with the 60's axle we have. Thing is the E-brake pull on the FL cars doesn't really have a "safety". It can pop off if bumped and that kinda sucks. I'm leaning towards a floor shifter to get the park function out of the 518, as cool as the buttons are, having the car roll away would suck. With the push button shifter in reverse, there is still some travel left in the cable mechanism. I've wondered if a second cable attached to a lever under the dash could be used pull/push the cable on the shifter/trans into the park position. Something that when released would give the shifter enough slack to operate normally. i have wondered the same thing, as i plan on using this transmission in my humpback project with a raised box on the driveshaft tunnel. with the stories about imperial services making me somewhat leery of sending in my shifter assembly for modification, i figure if they could come up with a modification that would work, i believe i can too. but i am a way from getting into that part of the build. however, i do keep my eyes and ears alert for ideas to make this happen.
[Re: moparx]
#2282776
04/05/17 12:44 PM
04/05/17 12:44 PM
Arominus
I'm still on the fence, i may be brave and just do the push button shift with the 60's axle we have. Thing is the E-brake pull on the FL cars doesn't really have a "safety". It can pop off if bumped and that kinda sucks. I'm leaning towards a floor shifter to get the park function out of the 518, as cool as the buttons are, having the car roll away would suck. With the push button shifter in reverse, there is still some travel left in the cable mechanism. I've wondered if a second cable attached to a lever under the dash could be used pull/push the cable on the shifter/trans into the park position. Something that when released would give the shifter enough slack to operate normally. i have wondered the same thing, as i plan on using this transmission in my humpback project with a raised box on the driveshaft tunnel. with the stories about imperial services making me somewhat leery of sending in my shifter assembly for modification, i figure if they could come up with a modification that would work, i believe i can too. but i am a way from getting into that part of the build. however, i do keep my eyes and ears alert for ideas to make this happen. Imp services does not have the greatest rep and they are not currently offering a cable. I had not heard that they had a conversion that added park though, just the cable that adapted the buttons to the newer trans. A&A sells the cable to just run the Push buttons with the newer trans with stock functionality. http://www.aandatrans.com/Products/Push-...le__AACCPE.aspx
