Satellite reverse light lever on steering column #2273700
03/21/17 03:00 PM
03/21/17 03:00 PM
fury4speed Offline OP
Mine is broken , any replacements out there? I tried to glue it but so far it does not hold , anybody have a fix , thanks.
1969 Satellite automatic , reverse light lever on steering column.
Re: Satellite reverse light lever on steering column [Re: fury4speed] #2273715
03/21/17 03:26 PM
03/21/17 03:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Satellite reverse light lever on steering column [Re: fury4speed] #2273798
03/21/17 05:47 PM
03/21/17 05:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '69 should have the transmission-mounted BU light switch. (introduced in 5-15-68)
Re: Satellite reverse light lever on steering column [Re: John_Kunkel] #2273812
03/21/17 06:00 PM
03/21/17 06:00 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that's what i thought. i was sorely tempted to slog through the snow to double check. could that be a '3 on a tree' thing??
Re: Satellite reverse light lever on steering column [Re: fury4speed] #2273982
03/21/17 11:10 PM
03/21/17 11:10 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
If it is the automatic with the indicator switch attached to the column, then its a plastic pin thats broken. According to the 1968 book the same one number was listed for all models using an automatic with column shift.
p/n 2883 211. If you check a '69 parts book to see if its listed, its in the steering section 19-46-44 as Pin, steering column gear tube switch, w/ auto transmission column shift.
Sometimes they show up. It takes some hunting and asking around.
One guy on FABO used a machine screwas a substitute.
https://www.forabodiesonly.com/mopar/threads/i-need-help-with-the-reverse-lights.292551/
Re: Satellite reverse light lever on steering column [Re: fury4speed] #2274114
03/22/17 08:37 AM
03/22/17 08:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
