Push rod length #227085
02/16/09 07:17 PM
02/16/09 07:17 PM
west palm beach, florida
modelmakerinc Offline OP
I had this in the race section with no replies So Ill try here.
Hey guys, Im going to buy a set of roller rockers and was wondering which would you recomend and the order in which to determine the pushrod length
I am considering the Comp Pro magnums which use ball/ball ends. I would like to do the whole swap in a day and need to know how to get the correct length pushrods. Is this something that can be done before having the rockers in place?
Or after install I need to measure for the pushrods and then order?
it is a 440 with 346 heads, milled .060 and it is a 533 MP hydraulic cam ?
any suggestions?, tips?
Thanks henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Push rod length [Re: modelmakerinc] #227086
02/16/09 07:21 PM
02/16/09 07:21 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You need to get the rockers on there and measure.
Re: Push rod length [Re: 69Cuda340S] #227087
02/17/09 09:06 AM
02/17/09 09:06 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
To get an accurate length this is the way you will have to do it .
Re: Push rod length [Re: JohnRR] #227088
02/17/09 09:24 AM
02/17/09 09:24 AM
Thank you, I thought so But I am a bit impatient when I do this type of thing, I hate having to order and install something just to order something else to finish.
Re: Push rod length [Re: modelmakerinc] #227089
02/17/09 10:06 AM
02/17/09 10:06 AM
JohnRR Offline
JohnRR  Offline
Unfortunately if you want to do it RIGHT thats what you have to do .
EDIT .... I just saw the heads were milled .060 , without knowing if the block has been decked AND if the the currect lifters are EXACTLY the same as the originals you would be rolling the dice on ordering a set ahead of time.
I see you are in West Palm , I was there on saturday ...
Re: Push rod length [Re: JohnRR] #227090
02/17/09 11:45 AM
02/17/09 11:45 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Just order the crane push rods for hydraulic lifters
with adjustable valve train and go on with your life.
People hear like to make simple things way to complicated for a mostly stock combo.
I think these are them
http://cranecams.com/?show=browseParts&a...Number=64673-16
worst case you may need to shim rocker shaft up a bit but I highly doubt it!!!!!!!!!!!!!!
Re: Push rod length [Re: Dodgem] #227091
02/17/09 12:03 PM
02/17/09 12:03 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I would measure first. The comp cams rockers need to have the adjuster's oil groove aligned with the rocker body's oil hole. If the push rod is not the right length the adjust may have to be turned out too far. This could result in blocking the oil to the push rod not to mention stressing out the adjuster. Every engine combination is different, that is why you need to measure. Do it right the first time and be done with it.
Re: Push rod length [Re: 69Cuda340S] #227092
02/17/09 12:19 PM
02/17/09 12:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would buy the crane gold rockers and the pushrods for hydraulic nothing fancy needed and has worked better than great for me and my friends in the past.
Adjust your preload and forget them
Re: Push rod length [Re: 69Cuda340S] #227093
02/17/09 12:34 PM
02/17/09 12:34 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I just went thru this with some Comp rockers. After some carefull measuring I determined that with 1 or 2 threads showing on the bottom of the adjuster screw the oiling groove in the screw was barely lined up with the oiling hole drilled in the rocker itself. In my case it won't matter as my hyd roller lifters have pushrod oiling and the pushrods are also drilled.
Re: Push rod length [Re: Classof70Chally] #227094
02/17/09 01:30 PM
02/17/09 01:30 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I have about 1 thread showing and from what I could see the oil hole would line up. 2 threads and I think its starts to get blocked, at least on the set I have. I run push rods with holes and lifters that oil too so no worries here. Comp really should have something about the push rod oiling in their instructions.
