Page 128 of 180 1 2 126 127 128 129 130 179 180
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2270531
03/16/17 01:58 PM
03/16/17 01:58 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I also need to research oil filters and find one that flows 20 to 25 GPM so I can use only one filter.The dual set up needs to be relocated to fit the "J" bars.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2270539
03/16/17 02:09 PM
03/16/17 02:09 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
You might want to take another measurement on the width of the k member cut. Make sure it is wide enough to remove the pan bolts front and sides. Don't ask how I know.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2270579
03/16/17 03:23 PM
03/16/17 03:23 PM
State of confusion
Thumperdart Offline OP
State of confusion
I've seen those dual deals cause more problems than good and do you REALLY need that...............
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2270697
03/16/17 06:47 PM
03/16/17 06:47 PM
fullmetaljacket Offline
That's more like dual Nuclear reactor towers.
Itis. Don't worry about the lines. I just wanna see that pup cut the gut.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2270756
03/16/17 08:18 PM
03/16/17 08:18 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Be interesting to see how much that whole remote setup weighs with all the lines, fittings and oil in it.
At a minimum there's at least a few lbs in extra fluid weight with the oil in the lines and those two big a$$ filters.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: RMCHRGR] #2270857
03/16/17 11:09 PM
03/16/17 11:09 PM
I agree again and thoroughly. I would suggest going lean and clean with that bullet. I'm sure that a lot has come a long way in the scope of oiling systems, fuel hose/coupling systems and such that new materials or the lack of so much equipment can still bring the same or better results to keep it light.
Itis, If you just went with a thin gauge 321 Military grade stainless exhaust system to copy what you have now, you'd save at the very least, 35-40 Lbs or more.
When I come over, I'm gonna bring a sample left over from my recent lightweight stainless exhaust system. A little pricey, but man, you gotta start some where with that Sumo Wrestling racer of yours.
Less weight, less effort, less breakage in getting to the stripe without a sweat gland opening.
If at the very least, try and relocate everything up front towards the rear, even if it's only an inch rearward. The transfer will astound you once the car finds that (Tipping point) sweet spot.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2270992
03/17/17 04:29 AM
03/17/17 04:29 AM
hemi-itis Offline
hemi-itis  Offline
Originally Posted By fullmetaljacket
If not this weekend, this coming week for sure.
Life and stuff get in the way,,,,,,,,,
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2271023
03/17/17 09:53 AM
03/17/17 09:53 AM
and you probably only know of half of it.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2271087
03/17/17 12:09 PM
03/17/17 12:09 PM
hemi-itis Offline
hemi-itis  Offline
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2271092
03/17/17 12:17 PM
03/17/17 12:17 PM
moparx Online content
moparx  Online Content
running stop signs plowing ? tsk biggrin
beer
Re: Real world weight loss program and it` cost.......... [Re: moparx] #2271110
03/17/17 12:53 PM
03/17/17 12:53 PM
I didn't know that there were street named signs on Long Island including STOP signs. LOL.
Re: Real world weight loss program and it` cost.......... [Re: dvw] #2271553
03/18/17 02:34 AM
03/18/17 02:34 AM
hemi-itis Offline
hemi-itis  Offline
Originally Posted By dvw
Uhm, I never thought of removing the fenders. That's even lighter than aluminum, glass, or even carbon fiber.
Doug
Doug, will it effect the Aerodynamics of the flying brick?? whistling
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2271556
03/18/17 02:36 AM
03/18/17 02:36 AM
hemi-itis Offline
hemi-itis  Offline
Can I use aluminum bolts for the fenders??
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2271633
03/18/17 10:16 AM
03/18/17 10:16 AM
Yes, you can use aluminum bolts to mount the fenders and a whole host of other things. I would NOT use 'em to mount the doors if they are stock weight. You'd be surprised at how much weight can be shaved in using lighter fasteners through out.
ALWAYS use anti-seize on the threads because of the different metals having issues with each others DNA.
We'll talk either tonight or tomorrow or Monday at the latest.
Re: Real world weight loss program and it` cost.......... [Re: moparx] #2271761
03/18/17 01:46 PM
03/18/17 01:46 PM
hemi-itis Offline
hemi-itis  Offline
beer
Time is MONEY$$When your doin the whole Village with stop signs on every coorner drive
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2272085
03/19/17 12:21 AM
03/19/17 12:21 AM
hemi-itis Offline
hemi-itis  Offline
3-4 Lbs at most.
Correct?
I didnt weight it but it feels like 3 lbs.IT more the upper half above the opening in the bottom of the "K".I was hoping for more,by the time we close it off,,,,,,it will be ZILCH savings.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2272128
03/19/17 01:48 AM
03/19/17 01:48 AM
Just make sure it is boxed and welds are done well. It is a crucial part.
Looks more like Monday now if not tomorrow evening.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2272282
03/19/17 12:42 PM
03/19/17 12:42 PM
hemi-itis Offline
hemi-itis  Offline
The latest cut in the "K" was just above the opening on the bottom.Looks like I can plate a few inches on the sides and maybe 6 inches on the front.The piece cut out maybe 2 lbs,,,,,
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2272427
03/19/17 04:45 PM
03/19/17 04:45 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Come on Al go all the way. Trim the flanges off.
Doug
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2272441
03/19/17 05:23 PM
03/19/17 05:23 PM
hemi-itis Offline
hemi-itis  Offline
Which flanges????????
