How to remove lead filler? #2270186
03/15/17 08:56 PM
03/15/17 08:56 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Can that stuff be melted with a standard blowtorch ??
Re: How to remove lead filler? [Re: Stanton] #2270190
03/15/17 09:01 PM
03/15/17 09:01 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Yep!
weld
Admiration For Multiple Carburetor Vehicles...
Re: How to remove lead filler? [Re: Stanton] #2270195
03/15/17 09:07 PM
03/15/17 09:07 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yes, it melts; that's basically how it's applied.
Obviously you don't want to use so much heat that you warp a panel, but it generally melts at a lower temperature than what's risky.
Lots of guys back in the day didn't use respirators when doing lead work, but I would recommend you do.
Re: How to remove lead filler? [Re: Stanton] #2270322
03/16/17 12:31 AM
03/16/17 12:31 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Don't use oxy/acetalyn. It's way hotter than you need and will risk damaging the steel. A plumbers propane torch is much cooler, but plenty hot to melt the lead. That's why it's a plumbers torch... they use it to...ah...melt solder onto copper pipes
**Photobucket sucks**
Re: How to remove lead filler? [Re: Stanton] #2270355
03/16/17 01:32 AM
03/16/17 01:32 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
iagree Hand held blue bottle torch is plenty hot enough to remove or apply lead.
Re: How to remove lead filler? [Re: Stanton] #2270358
03/16/17 01:33 AM
03/16/17 01:33 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Ok, thanks. I got rid of my oxy acetylene stuff years ago, that's why I was asking if propane would do it.
