66 coronet wheel and tire question #226405
02/16/09 04:37 AM
02/16/09 04:37 AM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
66 coronet wheel and tire question.
what would be the widest wheel and tire that i could fit in these small wheel wells. the car is jacked up on air shocks and i dont mind doing some cutting. i've been looking at those spring relocator kits and do a slight mini tub any advice on those kits?
also any one have pics?? of 66 or 67 b bodys with fat tires
Thanks!!!!!!!!!!
Re: 66 coronet wheel and tire question [Re: dirtycj5] #226406
02/16/09 11:05 AM
02/16/09 11:05 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
If you don't mind cutting the fenderwell lip, a 275/60-15 should fit, but will have to have perfect backspacing. 15x8 w/ 4-3/4" bs should be about right. I run 245/60-15's on 15x7's w/ 4-1/4" bs, and they fit with plenty of room to spare. If I had it to do again (which I will someday), I'd have ordered 255-60's. I think thats the most aggressive you can go without cutting the fender, or rubbing like crazy.
The inboard spring kit wont get you much. the inboard pinch spot is the fenderwell, not the spring. mini-tubbing and the inboard kit together will get you some nice space.
My experience comes from a 67 Plymouth. The Dodge version of this issue should be similar, though.
Re: 66 coronet wheel and tire question [Re: dirtycj5] #226407
02/16/09 11:08 AM
02/16/09 11:08 AM
Chesapeake Va
BobK Offline
BobK  Offline
Chesapeake Va
My 67 GTX has 275/60-15's on cop wheels with no rubbing. Stock suspension. Basically the same car as yours!
1964 Plymouth Fury x 2
1964 Plymouth Sport Fury
Re: 66 coronet wheel and tire question [Re: StealthWedge67] #226408
02/16/09 02:50 PM
02/16/09 02:50 PM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
how do you guys feel about a 15x8 wih 4.5 back space do you think it will hit the lip of the fender? thanks
Re: 66 coronet wheel and tire question [Re: dirtycj5] #226409
02/16/09 08:48 PM
02/16/09 08:48 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
The rear is the smallest imo. I was able to stuff a 10" section width tire in there with 1/2" to spare on either side. I needed a 5.5" backspace rim to do it.
Most people would call it a 5" backspace, but most all the wheel MFG's want 1/2" added on either side for the rim lip when giving the the backspace specs for custom wheels. They want you to measure from the edge of the rim, so an 8" rim is 9" in their world when talking backspace.
It's hard to see in the pic, but there is alot of rubber on the ground with a 10" section width tire. I needed 18" rims to clear the upper ball joint with 5.5" of backspace in the front. 18x8" wheels and 255/45/18" tires on all four corners. You can check the tire manufacturers web site to find other size tires that have a 10" section width.
Re: 66 coronet wheel and tire question [Re: Lefty] #226410
02/16/09 09:33 PM
02/16/09 09:33 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I recently installed 15 X 8 with 5 1/4" backspace with 245/60/15 tires on the rear of my 67 coronet. Fits very well into my stock wheel well..
Re: 66 coronet wheel and tire question [Re: Lefty] #226411
02/16/09 09:38 PM
02/16/09 09:38 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Lefty will you ever show a full picture of your car? Everytime the wheel question comes up you answer and post beautiful pics of the suspension and nothing else. Please post some pics.
Re: 66 coronet wheel and tire question [Re: BobK] #226412
02/16/09 09:42 PM
02/16/09 09:42 PM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
+1 My bothers 67 Satellite has the same combo on the rear with no issues. His leaf springs are pretty worn out too. I was also able to mount the same wheels in the back of my 67 Coronet 500 without any issues.
Re: 66 coronet wheel and tire question [Re: moparpollack] #226413
02/17/09 01:11 AM
02/17/09 01:11 AM
Lefty Offline
Lefty  Offline
I would like to but now I spend 7 days a week working on other peoples cars. My Coronet is in pretty much the same shape since that picture was taken. As soon as the 47 Dodge truck I'm working on is done, the Coronet get's it's spot in the shop and will be finished or I'm gonna go postal!
Re: 66 coronet wheel and tire question [Re: Lefty] #226414
02/17/09 08:29 AM
02/17/09 08:29 AM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
I run 28x9x15 slicks on my 66, or for the street I have 275x60x15's on centerlines, almost identical size between the slick and the 275's. Stock wells....I have heard it's tighter on the coronets, not sure why. If I remember correctly, they list the coronets at 117" wheel base and the satellites and belvederes at 116" so the the coronets are longer wheelbase.
Re: 66 coronet wheel and tire question [Re: Gary67] #226415
02/17/09 10:06 AM
02/17/09 10:06 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Before I mini-tubbed mine I ran 275/60 drag radials on a 15 x 8 street lite with 4.5 backspacing and the outer lip trimmed.I mini-tubbed it to the stock frame rails,moved the springs into the frame and have a 315/60 drag radial with 12 inch street lites.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: 66 coronet wheel and tire question [Re: 67HEMI] #226416
02/17/09 10:31 AM
02/17/09 10:31 AM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
67wedge thats what i wanted to hear.. do you have a pic of from the rear of the car with the 315/60's? do you know whats the bck space on the 12's thanks!!!
Re: 66 coronet wheel and tire question [Re: dirtycj5] #226417
02/17/09 10:36 AM
02/17/09 10:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have run 275/60/15's in the back on a 15x7 rim. it is tight. I also rolled the inner wheel lip up. They'd probably fit better w/ a 15x8 rim as it would not ballon the tire as much.
Re: 66 coronet wheel and tire question [Re: dirtycj5] #226418
02/17/09 10:36 AM
02/17/09 10:36 AM
Newark,De
hemi471 Offline
Happy Birthday hemi471  Offline
Newark,De
Here is mine!
Re: 66 coronet wheel and tire question [Re: dirtycj5] #226419
02/19/09 09:54 AM
02/19/09 09:54 AM
67HEMI Offline
67HEMI  Offline
Here are a couple. The backspace is 4 1/2". I used Afco slide links instead of shackles to keep it low plus we boxed the frame for the front spring hangers. Keeps it from looking like a 4x4
Re: 66 coronet wheel and tire question [Re: 67HEMI] #226420
02/19/09 01:24 PM
02/19/09 01:24 PM
west palm beach, florida
modelmakerinc Offline
67 Wedge, That is a beautiful car.
can you give a little more data on your rear tire brand and size I have BFG drag radials 345/65 15 which are not made anymore, they have a 12.5" tread and about 14" section on 10" wheels
I am having a hard time finding a set close to this size.
Post deleted by moparts [Re: modelmakerinc] #226421
02/19/09 01:42 PM
02/19/09 01:42 PM
Re: 66 coronet wheel and tire question #226422
02/19/09 07:09 PM
02/19/09 07:09 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I have 275/60/15 MT radials on 7 wide Weld prostars with 4 and 3/4 BS. Got 3/4 in spacing on both body and spring side with no rubbing. It's as tight as I would want to go. No issues so far tho. Changing rims is difficult tho. Gotta drop the rear susp. down fully to change.
These cars are always an issue to stuff large "meats" back there. A well planned spring relocation is probably the best solution.
Re: 66 coronet wheel and tire question [Re: modelmakerinc] #226423
02/19/09 09:32 PM
02/19/09 09:32 PM
67HEMI Offline
67HEMI  Offline
Thanks for the compliment.
Mine are 315/60/15 Mickey Thompson drag radials which are 12" tread 14" section on a 12" wheel.They are 30 inches tall. I think they would be just right for your car, they have less tread grooves than the BFG'S but they will hook My car has 1.47 60 fts with them
Re: 66 coronet wheel and tire question [Re: 67HEMI] #226424
02/20/09 08:25 AM
02/20/09 08:25 AM
Thank you 67 wedge, It is amazing how my tires which are wider do not look as wide as yours.
I will definetly look into thoses when I go to put on new rubber. henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
