six pack throttle cable
#2259418
02/25/17 07:42 PM
02/25/17 07:42 PM
Posts: 4,179 California
mickm
California
for a 70 B body, is the cable the same as the 440 cable?
any suggestions as to where to pick one up?
Re: six pack throttle cable
[Re: mickm]
#2259718
02/26/17 12:18 PM
02/26/17 12:18 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Took this from another thread
I'm getting this info from my dirrect connection performance book
426 hemi num 341841 19.50 overall 10 inch housing
440-6 num 341841 21.35 overal 11.75 housing
440 4 3769123 22.85 overall 13.25 housing
Abe Lincoln
[Re: dart4forte]
#2259796
02/26/17 02:04 PM
02/26/17 02:04 PM
mickm
California
440 4 3769123 22.85 overall 13.25 housing thanks for that! interesting, as I looked at those, I would think the 6 pack cable would be the longer one. both the center 2 bbl and the 4 bbl sit in the middle of the manifold, but the primaries of the 4 bbl would sit farther back toward the firewall, as from front to back it is a longer dimension than the 2bbl. anyway, I'll try and look those up.
[Re: mickm]
#2259805
02/26/17 02:17 PM
02/26/17 02:17 PM
dart4forte
Mesa, Arizona
440 4 3769123 22.85 overall 13.25 housing thanks for that! interesting, as I looked at those, I would think the 6 pack cable would be the longer one. both the center 2 bbl and the 4 bbl sit in the middle of the manifold, but the primaries of the 4 bbl would sit farther back toward the firewall, as from front to back it is a longer dimension than the 2bbl. anyway, I'll try and look those up. Glad I could help
Abe Lincoln
[Re: A12]
#2259827
02/26/17 02:41 PM
02/26/17 02:41 PM
Posts: 1,672 Virginia
HemiStan
Virginia
Mega Parts has a pretty good selection of throttle cables.
Stan
[Re: TOMRR]
#2259839
02/26/17 02:56 PM
02/26/17 02:56 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Not sure , I went from a 4 Barrel to a 6BBL on my 69 RR 4 Speed with a 440 and used the same cable !! Same here, always used the stock 4 bbl cable when going from 4bbl to 6bbl be it on a SmBlk, B,Blk or HEMI 6bbl induction, 68-70 Body, 71-2 Body, or 70-4 E body
[Re: DAYCLONA]
#2259861
02/26/17 03:21 PM
02/26/17 03:21 PM
mickm
California
Not sure , I went from a 4 Barrel to a 6BBL on my 69 RR 4 Speed with a 440 and used the same cable !! Same here, always used the stock 4 bbl cable when going from 4bbl to 6bbl be it on a SmBlk, B,Blk or HEMI 6bbl induction, 68-70 Body, 71-2 Body, or 70-4 E body Hemi 6bbl, that's what it's for! thanks!
[Re: HemiStan]
#2259867
02/26/17 03:24 PM
02/26/17 03:24 PM
mickm
California
Stan
good resource, thanks! they do list a separate cable for the 6bbl and the 4bbl. same price, so why not? I'll go with the 6bbl.
[Re: dart4forte]
#2259910
02/26/17 04:12 PM
02/26/17 04:12 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
440 4 3769123 22.85 overall 13.25 housing I think your part numbers are incorrect or for an E body / 71+ B body The correct part numbers for 70 RR should be: 2843751 - 426 Hemi 3418846 - 440 SIXPACK 3899339 - 383/440 4 barrel However I think most of us have gotten the 4 barrel cable to work
[Re: mickm]
#2259918
02/26/17 04:22 PM
02/26/17 04:22 PM
HemiStan
Virginia
Stan
good resource, thanks! they do list a separate cable for the 6bbl and the 4bbl. same price, so why not? I'll go with the 6bbl. mickm, I have bought quite a few items from Mega Parts over the years and they always seem to have good products. I highly recommend them. Stan
[Re: Morty426]
#2259928
02/26/17 04:33 PM
02/26/17 04:33 PM
dart4forte
Mesa, Arizona
440 4 3769123 22.85 overall 13.25 housing I think your part numbers are incorrect or for an E body / 71+ B body The correct part numbers for 70 RR should be: 2843751 - 426 Hemi 3418846 - 440 SIXPACK 3899339 - 383/440 4 barrel However I think most of us have gotten the 4 barrel cable to work I didn't research, just took it off another thread. It could be for those cars.
Abe Lincoln
[Re: dart4forte]
#2259931
02/26/17 04:38 PM
02/26/17 04:38 PM
Morty426
Sacramento CA
440 4 3769123 22.85 overall 13.25 housing I think your part numbers are incorrect or for an E body / 71+ B body The correct part numbers for 70 RR should be: 2843751 - 426 Hemi 3418846 - 440 SIXPACK 3899339 - 383/440 4 barrel However I think most of us have gotten the 4 barrel cable to work I didn't research, just took it off another thread. It could be for those cars. You were framed! LOL - no worries
[Re: mickm]
#2260502
02/27/17 02:31 PM
02/27/17 02:31 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
I've been through this twice. My car came 383 4bbl. and I swapped in a 440+6. What I found (been a few years) is that the stock 4 bbl. cable did not have enough "throw" for a six pack. What I mean by this is that the length of exposed metal cable on the carburetor side was not long enough to fully open the center carburetor.
Also, the E-body & '71-up B-body six pack cables (available from Direct Connection since the late 80's) have a square plastic plug where it goes through the firewall & my '70 has a round plug hole.
There may be accurate reproductions today. I've also wondered how hard it would be to get a long'ish cable & trim back some of the outer black plastic to get enough "thow" for a six pack.
Both times I replaced mine I bought a used original part.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: A12]
#2261146
02/28/17 05:46 PM
02/28/17 05:46 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
This is from Bill-A/gtx6970
Very interesting. From what I recall, the metal end (carb side) labelled as "S" in that diagram would hit the carb side of the outer cable (right side of what is marked "H") at about 85% of throttle opening of the center carb. I'm pretty sure the throttle cable on my '70 383 was original....but not positive. I'm also pretty sure that the A-12 throttle cable is the same as a '70 six pack. I'm curious why I see TWO six pack throttle cable numbers in Big E's chart.... is one (3418840) the '70 (round hole) and the other one (3418846) the '71 (square hole)? I would tend to think so since the 3418846 number lists "440 3x2 & 340 3x2" and since they only put the 340 3x2 in E-bodies.
