Tail shaft ID #225902
02/15/09 04:44 PM
02/15/09 04:44 PM
New York
R/T1968R/T Offline OP
New York
I found this in the garage. The mount location does not match my 68 B body and it doesnt look like an E body either. early B Body maybe?
Re: Tail shaft ID [Re: R/T1968R/T] #225903
02/16/09 03:01 AM
02/16/09 03:01 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
if its early itll have a non slip yoke flange on the rear of the tranny, it almost looks like a manual 3-speed.
Re: Tail shaft ID [Re: R/T1968R/T] #225904
02/17/09 09:13 AM
02/17/09 09:13 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What do you mean "the mount location doesn't match" ???
Re: Tail shaft ID [Re: JohnRR] #225905
02/17/09 09:42 AM
02/17/09 09:42 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
The tailshaft number 69' B-body 18 spline. Auto and 4-speed crossmember mount are different.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Tail shaft ID [Re: 64dodge572] #225906
02/17/09 01:16 PM
02/17/09 01:16 PM
New York
New York
Thanks, makes sense now. I forgot there was a 4 speed cross member.Thought they were the same.
