yup - you can see that even at the 1.8 psi ratio you're calculating (12psi and considering no loss to get the 12psi which is probably not a safe assumption with these) you're just about off the end of the island of 60% eff at 7psi you'd be well off.
70 Sport Fury
68 Charger
69 Coronet
72 RR
