transmission cooling pump #2257488
02/21/17 11:51 PM
02/21/17 11:51 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
A buddy of mine runs a glide and just installed a Titon transmission pump to cool the trans fluid through the cooler in between rounds. He said he doesn't have to run it during the race as the internal transmission pump will circulate the fluid. It seems to me that it would cause restriction and cause more heat. Does anyone on here run a separate trans pump to cool down between rounds? do you run the pump all the time?
Re: transmission cooling pump [Re: rowin4] #2257504
02/22/17 12:10 AM
02/22/17 12:10 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My Friends sells and owns this company.
http://jonestransmissionpumps.com/HowItWorks.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
