Battery Switch Mounting::: SOLUTION Found
#2252313
02/12/17 03:42 PM
02/12/17 03:42 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Looking for some ideas on where to mount the trunk battery switch. Don`t like the idea of it hanging under the bumper,not sure if I could live with drilling a hole in my newly chromed bumper either.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Battery Switch Mounting
[Re: RealWing]
#2252351
02/12/17 04:20 PM
02/12/17 04:20 PM
6bblFLASH
N.E. Ohio
Very nice.
But unless the rule has changed,does`nt the switch have to accessible in case of an accident per NHRA rules?
If I can put it in the trunk AND be legal,problem solved!
[Re: 6bblFLASH]
#2252373
02/12/17 04:48 PM
02/12/17 04:48 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
From 2010 NHRA rules
8:4 MASTER CUTOFF Mandatory when battery is relocated, or as outlined in Class Requirements. An electrical power cutoff switch (one only) must be installed on the rearmost part of each vehicle and be easily accessible from outside the car body. This cutoff switch must be connected to the positive side of the electrical system and must stop all electrical functions including magneto ignition. The off position must be clearly indicated with the word “OFF.” If switch is “push/pull” type, “push” must be the action for shutting off the electrical system, “pull” to turn it on. Any rods or cables used to activate the switch must be minimum 1/8-inch diameter. Plastic or keyed switches prohibited. Switches and/or controls must be located behind rear wheels on rear-engine dragsters.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: 6bblFLASH]
#2252797
02/13/17 03:31 AM
02/13/17 03:31 AM
Posts: 1,101 Massillon, Ohio
cudatom
Massillon, Ohio
Dennis if you go w/a push pull set up can you notch or trim your lisc plate and bracket so that it will still open
Ok
[Re: cudatom]
#2252834
02/13/17 09:35 AM
02/13/17 09:35 AM
6bblFLASH
N.E. Ohio
Tom,I was looking at some of the push /pull setups. I think I might be able to get the rod go beside the license plate. I am going to put the gas tank in 1st and what fits.
[Re: 383man]
#2253920
02/15/17 04:13 AM
02/15/17 04:13 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Dont know if you can do like I did. But I wont drill a hole in my car or bumper so I drilled a hole in the taillite lens. I have spare lens if I ever want to take it out. My bulb is in the center so the way I mounted mine all the lites still work normal and all I messed up is the taillite lens by drilling a hole in it. Ron I had a '64 Polara with the two piece rear finish panel and had the battery mounted in the trunk behind the right rear tire. I never did put a switch in the car and moved the battery back under the hood when I sold it. I was at the track one day and saw a serious race '64 Polara and the owner had drilled a hole in a perfect finish panel and mounted switch there...I just about cried!!! Those panels are impossible to find without pits. I built a new bumper for my Ramcharger, it adds ballast and the switch is protected.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: Battery Switch Mounting : SOLUTION
[Re: 6bblFLASH]
#2255984
02/19/17 02:27 PM
02/19/17 02:27 PM
6bblFLASH
N.E. Ohio
Here is what I came up with, nothing to obvious.
[Re: 6bblFLASH]
#2255985
02/19/17 02:30 PM
02/19/17 02:30 PM
6bblFLASH
N.E. Ohio
Handle,and switch location
[Re: stumpy]
#2256169
02/19/17 06:56 PM
02/19/17 06:56 PM
6bblFLASH
N.E. Ohio
Thanks, took all day to fab,fit-rework until it was good. I am happy with it. Except for the label I will have to put on the bumper. Practically un noticeable .
