Hemi 4024S Fuel Pump Repair #2256361
02/20/17 12:54 AM
02/20/17 12:54 AM
VA
dragon slayer Offline OP
VA
Is anyone making a kit to repair a Hemi Carter Fuel pump 4024S?
Re: Hemi 4024S Fuel Pump Repair [Re: dragon slayer] #2256370
02/20/17 01:10 AM
02/20/17 01:10 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I restore them if you want the works, includes a test run on my fuel pump stand. In answer to your question, yes, kits are made and sold by a couple companies but I have to customize any one of them to work properly, they are not correct out of the box.
Re: Hemi 4024S Fuel Pump Repair [Re: ScottSmith_Harms] #2256575
02/20/17 02:16 PM
02/20/17 02:16 PM
Ebay might just have the bare bones rebuild kits. If the price was reasonable I would & you could compare the new to the old side by side & if anything is bad/out of spec you could return it for a refund. Take pics in case they squawk & if plastic sealed, open the pkg as non invasively as possible. Refunds are not what they are about. Holler how it turns out.
