Biggest rotor you can fit on a stock 73 A disc knuckle ? #2256471
02/20/17 07:52 AM
02/20/17 07:52 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I see many kits for drum knuckles. Maybe this is because most cars need the conversion?
I have the 1975 Dart knuckles in my Charger. The rotors are the 11.75 Cordoba discs. I've wondered about increasing the rotor size but don't recall seeing anything listed for disc knuckles.
What have you heard ?
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2256511
02/20/17 11:55 AM
02/20/17 11:55 AM
Colorado
Bob J Offline
Bob J  Offline
Colorado
15" front talk with Magnum Force but that is a 6 piston. You can go to 12.19 with 4 piston with the Wilwood kits. I'm not sure on other kits.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2256565
02/20/17 01:51 PM
02/20/17 01:51 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Your wheel diameter will limit you, not your spindle. (at least when it comes to making mounts for what ever rotor and caliper combo you'd want)
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: OzHemi] #2256911
02/21/17 12:05 AM
02/21/17 12:05 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks. I have an 18x9 front wheel. I thought the common belief was that the rotor usually has to be 3" smaller than the wheel diameter.
No, I do not need a 15" rotor to stop the car, I was just wondering and mulling the options.
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2256980
02/21/17 02:07 AM
02/21/17 02:07 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Would depend on your wheel design too along with how high your caliper sits up off the rotor. I have 360mm rotors with Brembos and they clear my 18" rims...but not a ton of room to spare.
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2258859
02/24/17 06:32 PM
02/24/17 06:32 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The wheel shell and spoke design also play a roll on caliper/rotor offset. If the rotor has enough inset you can fit more common off the shelf wheels.
Mopar to the bone!!!
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2259776
02/26/17 01:41 PM
02/26/17 01:41 PM
what about some aggressive nascar pads & a breakin (bed in) procedure. it'd be the easiest upgrade.
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2259830
02/26/17 02:44 PM
02/26/17 02:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nascar pads?
Nascar pads, if truly for Nascar applications and not just a gimmick name, are designed for serious high speed and high heat applications, probably gonna be horrible on a street car. Ever see the video of the rotors glowing cherry red when they put on the brakes during a race?
Don't be the exception.
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2259833
02/26/17 02:49 PM
02/26/17 02:49 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Race pads on street = Front end body work
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2260690
02/27/17 09:09 PM
02/27/17 09:09 PM
AndyF Offline
AndyF  Offline
It depends on the shape of the parts but back when I was building 13" brake kits they were all designed to work with Ford Mustang 17 inch rims. So if your 18" rims are caliper "friendly" then you should be able to put a 14" rotor in there. A 13" rotor with a big caliper should easily fit inside an 18" rim unless you have the world's worst wheel design.
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Bob J] #2260778
02/27/17 11:27 PM
02/27/17 11:27 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I believe the SuperSpeedway pads often have a low temp usefulness and aggressiveness, since they are seldom used, but hugely important for pit stops, and cooled constantly by high speed air. I suspect we are mainly talking brake compound selection, as the hardware is super expensive, even used. twocents
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2260814
02/28/17 12:21 AM
02/28/17 12:21 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
This is the Dr Diff cobra kit (13" rotor) with an 18x9. Just bolted it on, its an easy swap, but haven't driven the car yet. If you wanted opposed piston caliper you would need rotors with a deeper hat (more offset to the knuckle side). The wheels are Torque thrust M's, which are basically mustang wheels as well.
There are a lot of pads available for this application (94-04 Mustang Cobra). I also bought the rear kit (11.75 rear disk that is vented), but haven't started the install yet.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2261737
03/01/17 06:10 PM
03/01/17 06:10 PM
AndyF Offline
AndyF  Offline
Looks good. That is a really good "bang for the buck" way to put big rotors and good wheels/tires on a Mopar. You'll notice a big, big difference compared to the factory setup.
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: AndyF] #2261974
03/02/17 01:28 AM
03/02/17 01:28 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
How much benefit is there going from the Dr Diff Stage 3 kit with the Cobra calipers and the 4 piston Brembos on the Stage 4?
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Skeptic] #2262052
03/02/17 04:07 AM
03/02/17 04:07 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Don't know, but mine stop pretty well with manual brakes. Sorry, I don't have a close up.
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: goldduster318] #2265464
03/08/17 10:23 AM
03/08/17 10:23 AM
CT - just outside Hartford
Crazy73 Offline
Crazy73  Offline
Yep, I've got the same 13" kit from Dr Diff but with 17x8 in front, 18x9 in rear. The rear are his 13" kit as well. Hopefully I get to stomp the stop pedal later next weekend, the car isn't on the road yet.
Pete
-1968 Barracuda 4spd 383-6pk
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2266062
03/09/17 07:57 AM
03/09/17 07:57 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
You have a 13" rear brake kit? I didn't know anyone offered anything that big for a rear brake setup.
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2266144
03/09/17 12:42 PM
03/09/17 12:42 PM
Crazy73 Offline
Crazy73  Offline
Yep, a 13" rear kit! I bought the kit from Dr Diff back in early 2008, but looking at his website this morning it doesn't appear as though he offers it any longer.
Here's a poor pic w/ wetsanded quarter panel, but they are the Cobra rear calipers w/ parking attachment. I believe the rotors in this kit at the time were Porsche.
Pete
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2269299
03/14/17 01:07 PM
03/14/17 01:07 PM
Crazy73 Offline
Crazy73  Offline
Here's a better pic of the 13" rear disc assembly, sorry about the tarnish!
17309087_10154927945053787_8088211201762061245_n.jpg17264475_10154927945018787_8847937412868019456_n.jpg
Pete
Re: Biggest rotor you can fit on a stock 73 A disc knuckle ? [Re: Kern Dog] #2269684
03/14/17 11:50 PM
03/14/17 11:50 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Yeah, those kits are gone. I believe they were SRT rotors, but don't quote me on that.
