Mopar small block cylinder p5249574 #2254895
02/17/17 02:46 AM
02/17/17 02:46 AM
p.a.
420duster Offline OP
p.a.
Can anyone tell me anything about these heads ? I tried searching didn't find much. Specs ? Any good ? Thank you !
Re: Mopar small block cylinder p5249574 [Re: 420duster] #2254923
02/17/17 09:10 AM
02/17/17 09:10 AM
swirl port. 5 bolt valve covers. 166CC intake volume. 18 deg valve angle. bare machined head. machined in seats/guides/spring seats/valve gear. 340 HP head machined for 2.02/1.60 valves, std & W2. best pre magnum production casting. all info copied directly from 2001 MP catalogue.
Re: Mopar small block cylinder p5249574 [Re: RapidRobert] #2254951
02/17/17 11:17 AM
02/17/17 11:17 AM
p.a.
p.a.
Thank u ! Just bought a 71 Duster and these heads are on the 340 motor.
Re: Mopar small block cylinder p5249574 [Re: 420duster] #2255064
02/17/17 03:49 PM
02/17/17 03:49 PM
dogdays Offline
dogdays  Offline
IIRC they're identical to the 308 head.
R.
Re: Mopar small block cylinder p5249574 [Re: 420duster] #2256286
02/19/17 10:47 PM
02/19/17 10:47 PM
p.a.
p.a.
Whats the combustion chamber cc's ?
Re: Mopar small block cylinder p5249574 [Re: 420duster] #2258364
02/23/17 10:20 PM
02/23/17 10:20 PM
dogdays Offline
dogdays  Offline
68 - 73, same as the other 360-style heads. Probably the higher end.
R.
