440 Source Roller Rockers #2251394
02/11/17 01:26 AM
02/11/17 01:26 AM
illinois
bigblk66_coronet Offline OP
illinois
Has anyone used the 440 Source roller rockers? If so what did you think of them? thanks joe
66 Dodge Coronet 500 440w/727 11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust Best ET. 12.38 @110 in street trim
Re: 440 Source Roller Rockers [Re: bigblk66_coronet] #2251408
02/11/17 01:49 AM
02/11/17 01:49 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
The price alone should tell you everything you need to know...Junk. I've seen rockers break and dislodge keepers, dropping a valve, so I wouldn't trust budget pieces. That company is good for cheap water pump housings, ARP bolt kits, and girdles. Everything else is "get what you pay for"
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 440 Source Roller Rockers [Re: bigblk66_coronet] #2251421
02/11/17 02:15 AM
02/11/17 02:15 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
"Just say no"
Re: 440 Source Roller Rockers [Re: bigblk66_coronet] #2251441
02/11/17 02:48 AM
02/11/17 02:48 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Not personally, but I warned a buddy against it after reading all the negative reviews here. He did it anyway. They failed.
**Photobucket sucks**
Re: 440 Source Roller Rockers [Re: bigblk66_coronet] #2251562
02/11/17 01:19 PM
02/11/17 01:19 PM
Idaho
LaRoy Engines Offline
Idaho
I have had good service from the company 440 Source. The rockers are like any inexpensive rocker. Don't stress them severely. I ran them briefly on a 780 HP 7,400 rpm 451 stroker. Pulled them and put them on the grandson's hydraulic roller in his pickup truck. They've be on there for years.
Re: 440 Source Roller Rockers [Re: bigblk66_coronet] #2251566
02/11/17 01:25 PM
02/11/17 01:25 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
have a set on dad's 440, solid cam 155 seat 380 open, they hit the retainers so needed clearanced and they tore up the shafts.
Re: 440 Source Roller Rockers [Re: twayne24365] #2251832
02/11/17 09:13 PM
02/11/17 09:13 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I have them on my Duster. I am just under .700 lift, and I have had a few issues with them initially. They kept backing off...Turns out the adjusters were bad. Put in a set of Hughes adjusters, and haven't torn anything up in a while. I do keep spares though.
I run my wedge stuff with mostly 440source parts and really not to many issues.
