Fuel Pump Relay & Street Fuel Pump #225055
02/14/09 09:29 PM
02/14/09 09:29 PM
U.S.
moparniac Offline OP
U.S.
Single Pole or double pole.....
what is the best street strip pump that can handle long cruises
thx
Mopar Performance
Re: Fuel Pump Relay [Re: moparniac] #225056
02/14/09 09:30 PM
02/14/09 09:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My bosch 30 amp has 4 posts thats all I know. I`m running the holley billet 150 pump w/a dead head system works great and doesn`t overheat.
Re: Fuel Pump Relay [Re: Thumperdart] #225057
02/14/09 09:46 PM
02/14/09 09:46 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
I've got 6 troublefree years on my holley blue pump. I used the painless fuel pump relay kit.
Re: Fuel Pump Relay & Street Fuel Pump [Re: moparniac] #225058
02/14/09 09:46 PM
02/14/09 09:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A single pole relay is what you need, a double pole relay basically is designed to complete a circut without power then open that circut & complete another circut when power is applied...A single pole relay will have four posts, power in,power out, signal input & either power or ground depending on the signal input...
Pump is very much your choice...
Re: Fuel Pump Relay & Street Fuel Pump [Re: moparniac] #225059
02/15/09 02:55 AM
02/15/09 02:55 AM
thx
Magnafuel of the proper size for your motor Call magnafuel for the proper sizes
Re: Fuel Pump Relay & Street Fuel Pump [Re: moparniac] #225060
02/15/09 03:08 AM
02/15/09 03:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You only need a single pole relay and an in-line fuse.
I don't know whick pump is best. I have a Mallory and it has worked fine for years, but it is not quiet. In fact I don't know of any performance electric fuel pumps that are quiet?
