Re: Changing speedo gear???
[Re: A727Tflite]
#2251106
02/10/17 04:37 PM
02/10/17 04:37 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You can disagree all you want - what do you have to back it up? My actual measurements...try it yourself.
[Re: BDW]
#2251235
02/10/17 08:37 PM
02/10/17 08:37 PM
John_Kunkel
Rio Linda, CA
Example, the manufacturer of my 235/70R15's says they are 28" in diameter but the rollout is 84" which equates to a diameter of 26.73".
[Re: Sxrxrnr]
#2251743
02/11/17 06:25 PM
02/11/17 06:25 PM
John_Kunkel
Rio Linda, CA
At the risk of repeating myself, I think it's ill-advised to change a speedo pinion based on a GPS speed readout; the odometer is the best indicator of correct/incorrect pinion, not the speedometer. If the odometer is correct, then any speedo error is in the head, not the pinion.
[Re: John_Kunkel]
#2251799
02/11/17 08:02 PM
02/11/17 08:02 PM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
Thank you John, for the clarification. That's why I like Moparts.com
[Re: STROKIE]
#2252816
02/13/17 05:33 AM
02/13/17 05:33 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Thank you John, for the clarification. That's why I like Moparts.com The above illustrated app if you forego the 'free' version and step up to the paid version(2 bucks was what I paid) you get among other niceties, includes odometer support and a history/log file. . The cost of a small order of fries at Macdonald's. What could be simpler and more effective?
[Re: Sxrxrnr]
#2252912
02/13/17 01:32 PM
02/13/17 01:32 PM
RapidRobert
Agreed, with the right speedo gear the ODO will automatically be corrected & most always then the magnetic gismo speedo will also be correct & if not then the speedo head in that rare case will need to be sent to a speedo specialty shop to be recalibrated (or another one at a boneyard may be cheaper).
[Re: BDW]
#2253588
02/14/17 04:09 PM
02/14/17 04:09 PM
John_Kunkel
Rio Linda, CA
The same size tire from the same manufacturer can be different in diameter due to coming from different molds and the diameter of the same tire will vary with the width of the wheel it's mounted on.
