Anyone good with OBD II code readers? 98 dodge van
#2248074
02/05/17 10:31 PM
02/05/17 10:31 PM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
hey guys, a buddy of mine asked me to help him with his 98 dodge van with a 360. It has 110,000 miles. It needed a downstream oxygen sensor as the "check engine" light was on. I replaced it with a Bosch unit and reset the code reader. The check engine light then stayed off. Now, everything is working properly but I cannot get the "catalyst monitor" code to reset. There are no pending codes and the guy at the smog check inspection station(I'm in kommiefornia) said sometimes you have to drive the car for hundreds of miles before it will reset. He claims this is a dodge thing. He does own a garage also and said that there is nothing wrong with the computer or the engine. I just need to keep driving. I have driven this van for over 200 miles already. Anyone have any ideas on why this code won't reset? I have included a pic of the code reader. Thanks in advance!
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
Re: Anyone good with OBD II code readers? 98 dodge van
[Re: hosehead]
#2248104
02/05/17 11:14 PM
02/05/17 11:14 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Yes. All monitors need to get set after erasing a code. Basically, you need to run through every possible engine load situation for the computer to say 'ok, we're good now.'
Part throttle cruise downhill, uphill, flat ground, WOT hot, cold, stop n go traffic, closed throttle coasting... 500 miles of highway alone won't cut it.
**Photobucket sucks**
[Re: hosehead]
#2248125
02/05/17 11:32 PM
02/05/17 11:32 PM
hosehead
Grove, OK
Thanks 70cuda383. That's what I was afraid of.
[Re: hosehead]
#2248316
02/06/17 08:28 AM
02/06/17 08:28 AM
Posts: 5,924 ohio
ruderunner
ohio
As stated, the puter has a set of self tests it Hhas to run.most require a certain combination of throttle/speed/rpm etc. Some are even affected by outside temp.
I know evap monitor won't run if its too cold outside, but I don't think cat monitor is like that.
Are any other monitor not complete?
Angry white pureblood male
[Re: ruderunner]
#2248416
02/06/17 01:11 PM
02/06/17 01:11 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Is that the only monitor that is incomplete? The monitors run in a sequence and need to pass before the next one runs. If I were in your shoes I'd replace the upstream O2 sensor, they can be slow or biased lean/rich and not set a code and still cause issues. The ECM watches the O2 switching rate and the voltage and compares them. A fresh rear sensor will often flag a lazy old front sensor. Don't be surprised if you get a P0420 (Catalyst Failure) either way. Other than that the basics apply, clean oil, engine getting up to temp, NO exhaust leaks!, functional EGR, Good basic tune, Etc. If you really want to know just Google "OBDII drive cycle" It's not a secret, but it can be a PITA to run without a dyno programmed for it.
[Re: Skeptic]
#2248434
02/06/17 01:34 PM
02/06/17 01:34 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Is that the only monitor that is incomplete? The monitors run in a sequence and need to pass before the next one runs. If I were in your shoes I'd replace the upstream O2 sensor, they can be slow or biased lean/rich and not set a code and still cause issues. The ECM watches the O2 switching rate and the voltage and compares them. A fresh rear sensor will often flag a lazy old front sensor. Don't be surprised if you get a P0420 (Catalyst Failure) either way. Other than that the basics apply, clean oil, engine getting up to temp, NO exhaust leaks!, functional EGR, Good basic tune, Etc. If you really want to know just Google "OBDII drive cycle" It's not a secret, but it can be a PITA to run without a dyno programmed for it. Wow, I agree that you might need an upstream O2 sensor too if the code hasn't cleared in 200 miles. It's too bad that those "driving requirements to reset computers" are kept so secret by the OEM's, but 200 miles sounds like a lot. I reset my Mustang's computer driving 10 miles, turn off/on & drive 5 more miles and it's OK (found this out by trial and error). I don't want to jinx you, but my wife's Sebring had a code that just wouldn't clear and I had to replace the computer. I hope that's not the case for you. I had no choice since I had a deadline to get her license plates renewed with the emission test.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: hosehead]
#2249150
02/07/17 04:12 PM
02/07/17 04:12 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
Like 71GTX471 said, not sure how it is state by state, but here in WI you are allowed some unset readiness indicators based on year. I think WI is identical to what he said or close - I just had to nurse my dad's 99 Buick through with 2 I could not get to set. Some of the older cars it is a real bear to get them to set, and I believe emissions people have realized that hence the rule.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: moparjimbo]
#2250164
02/09/17 03:12 AM
02/09/17 03:12 AM
hosehead
Grove, OK
Thanks for all the replies, guys! I think I will go ahead and check into the upstream sensor after doing some more driving this weekend. The guy at the smog shop says he can't pass it with even one incomplete. Thanks again. I'll keep you posted!
