20 inch springs or longer? #2248044
02/05/17 09:39 PM
02/05/17 09:39 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So I have a 69 barracuda and was wondering if I should use longer springs ( front section) in order to get better traction and control.
In using a longer front section, does it act like an extension on a ratchet? More control with less effort?
Also in doing so I can centre the tire inside the wheel well so I don't have to cut my fenders for larger tires.
Matt
Re: 20 inch springs or longer? [Re: MattW] #2248059
02/05/17 10:04 PM
02/05/17 10:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Drag use is a specialized application imo, but normal performance suspension design theory favors suspension links longer the better, within reason. However a leaf has multi tasks, each task assigned can negatively effect the others, depending on the parameters, its a compromise. twocents
Re: 20 inch springs or longer? [Re: MattW] #2248227
02/06/17 01:36 AM
02/06/17 01:36 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
How much power? What tire?
Re: 20 inch springs or longer? [Re: MattW] #2248269
02/06/17 02:30 AM
02/06/17 02:30 AM
pennsylvania
poboyengineering Offline
pennsylvania
The longer spring will move the leverage point, but the short spring will be stiffer. If you keep the front segment as stiff as the short spring there may be some gains.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: 20 inch springs or longer? [Re: poboyengineering] #2248302
02/06/17 04:29 AM
02/06/17 04:29 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
With a Caltrac or similar traction device, the old stiff front segment idea basically becomes a moot point. If you choose to go this route, Calvert can build a split mono with either a 24" or 25" front segment.
I don't really see any negatives.
I do recall Monte talking about some theories of his that made a lot of sense. Hopefully he chimes in, I don't want to get it wrong and be misleading
Alan Jones
Re: 20 inch springs or longer? [Re: LA360] #2248757
02/06/17 10:12 PM
02/06/17 10:12 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
IT will be split monos springs along with assassin or calvert bars. 275 drag radial.
Matt
Re: 20 inch springs or longer? [Re: MattW] #2248835
02/06/17 11:50 PM
02/06/17 11:50 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The point of the two, listed bars is to make the front section stiffer, so I would go with the standard length A body length section. Unless you could use more front tire clearance on the tire vs wheel well clearance. Your best bet is to stick with the length you have now. A longer front section will have a effect on drive shaft length But, there is a spacer bracket you can use to negate effect as well.
How fast is your ride? What kind of performance et are you expecting or planning for?
Re: 20 inch springs or longer? [Re: MattW] #2248916
02/07/17 02:12 AM
02/07/17 02:12 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I went from 20's to 25's and immediately noticed a difference on my 72 Dart at around 3050 lbs but I'm not that fast and heard Digby(sp) runs the 20's so shruggy ..............The rear sliders and mounting the shocks upright also made my car react quicker/better and so far a 1.33 60 ft. foot brakin at 2500 w/more to come here soon.........seemed like a smoother ride also........ beer
Re: 20 inch springs or longer? [Re: Thumperdart] #2248918
02/07/17 02:14 AM
02/07/17 02:14 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
How far did the longer segment move the wheel back Dom?
Re: 20 inch springs or longer? [Re: Jeremiah] #2248933
02/07/17 02:53 AM
02/07/17 02:53 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The spring is 5 inches longer, you move your front mounting point. You can then chose where ever you want your tire.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 20 inch springs or longer? [Re: 1967dartgt] #2248992
02/07/17 10:48 AM
02/07/17 10:48 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I'm setting the car up for low 8 secs. Whether I get there or not is another matter.
I want to build it once. If it's easier to set up a 25" over a 20" at the track then so be it I'll put in the 25.
Re: 20 inch springs or longer? [Re: MattW] #2248994
02/07/17 10:52 AM
02/07/17 10:52 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Like what's been said, both can work especially in that range. On paper the 25 is better. My car has 20" segment and I haven't had any problems that I would blame them for.
I guess it's your call is kinda what it comes down to.
Re: 20 inch springs or longer? [Re: MattW] #2249022
02/07/17 12:14 PM
02/07/17 12:14 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
seems I remember people discussing the longer sections.... but then pointed out Jason Digby was still running the 20" segment.
Re: 20 inch springs or longer? [Re: MattW] #2249039
02/07/17 12:42 PM
02/07/17 12:42 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Check out my build thread. I did 25 inch front with fabbed front and rear mounting.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: 20 inch springs or longer? [Re: MattW] #2249043
02/07/17 12:46 PM
02/07/17 12:46 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Nice looking set up quick runner.
Re: 20 inch springs or longer? [Re: Jeremiah] #2249053
02/07/17 01:07 PM
02/07/17 01:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I didn't move the rear back just moved the ft. box 5"'s forward into my sub-frame connectors which stiffened it up even more........
Re: 20 inch springs or longer? [Re: Thumperdart] #2249778
02/08/17 05:05 PM
02/08/17 05:05 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I see, thanks for the info. I'm thinking of trying a longer front segment to move the tire away from the wheel arch a little. Looks like a call to Calvert is in order.
I'll assume a 4" longer spring won't move the wheel back 4". Thoughts?
Re: 20 inch springs or longer? [Re: J_BODY] #2249826
02/08/17 06:14 PM
02/08/17 06:14 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Digby's car is fast, no doubt. But so far they haven't been able to get it to 60ft anywhere near where they would like it to. So, is that due to short segment, or they just haven't nailed the setup yet? Remains to be seen. So far when they have tried to 60 it much harder than 1.14 or so, it's knocked the tires off and we know of leaf cars that go 1.0s. So they still have work to do. Lyle and I were discussing this very issue in Bradenton.
Now while we don't have many fast leaf Mopars to base any conclusions on, we do know, as mentioned above that there are several fast leaf cars that 60ft in the 1.0s. Those are GM cars. That doesn't really mean anything either, EXCEPT those cars all have longer front segments........so, form your own conclusions. I think either will likely work, but maybe one is easier to make work
The hardest 60 footing leaf car that I know of, is Ron Rhodes. He has been 1.04, maybe quicker, but the car is light which helps. But I also know of some in the 3000lb range that have been in the 1.0s as well
Re: 20 inch springs or longer? [Re: MattW] #2249964
02/08/17 10:32 PM
02/08/17 10:32 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Didn't know you were willing to go to 25" when I posted. In that case yes, I would go with it.
When you get the shorter segment to become stiff, it needs a lot more shock resistance to control its movement. The longer lever will be better in your case. It can be done though, as others are doing it, with the shorter stock option segments.
Re: 20 inch springs or longer? [Re: Sport440] #2249982
02/08/17 11:04 PM
02/08/17 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It comes down to HP and the CG of the car..
in theory you want the bars or IC to lift from
not too far behind the CG of the car to give the
max loading on the bars/springs... then if you
add boxes to it you would want to lower them for
a longer sustained hit
wave
