Re: Jensen Interceptor.... :p
[Re: autoxcuda]
#224824
02/20/10 12:41 AM
02/20/10 12:41 AM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
Thanks for the pics! I figure I will swap out tips at a later date, I'm trying to get it on the road right now. It's running, driving, stopping and steering, I have a real issue with lack of traction, but that's another story..... Car runs strong, but I'm still working the bugs out....
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224825
02/20/10 01:40 AM
02/20/10 01:40 AM
Don't forget to come and take me for a ride.
[Re: CrAzYMoPaRGuY]
#224827
06/12/10 04:30 PM
06/12/10 04:30 PM
CrAzYMoPaRGuY
Canada
Well after a few months of house renos, I started putting away tools, which lead to opening up the garage, which lead to pushing my Coupe out which in turn required the Jensen being moved.... SoooOooo.... I just HAD to start working on the Jensen a wee bit... LOL Got my front end nicely settled at ride height, so I have tightened up all my suspension and threw in some cotter pins. I noticed my toe-in was out by quite a bit, so I did an eyeball alignment which I hope is good enough to get me to the alignment shop. Made pieces to fasten both the chokes open and installed them... and I changed my turn signal stalk to a proper Interceptor turn signal stalk. I have to get the wiring ends on but I tested it and it indeed works like I should! I have to get my windows working (I removed my AC and will retrofit later) and then I think I am on the road!!!!!! I have two new K&D switches, and access to quite a few window motors.... so I just have a bit of work to do on the windows, finish my stereo install, and then I am on the road for the summer! I'll post pics of my breakdowns, videos of me pushing the car home, and the amount of tears I shed in future posts....
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224829
06/19/10 05:14 PM
06/19/10 05:14 PM
CrAzYMoPaRGuY
Canada
Dun-dun-DUH!!!!!! Insured it today.... it actually drives pretty danged good so far. Only 20 minutes cruising so far, but drives straight, shifts nice, corners flat, it seems pretty good. A little bit of DrOnE at ilde and cruising speeds though... but I have my driver's door panel off and both windows were down... Gotta start sorting out the bugs and taking a few longer trips, but so far I am a HAPPPY camper!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224833
06/26/10 12:59 PM
06/26/10 12:59 PM
CrAzYMoPaRGuY
Canada
Out cruising last night for a couple of hours....
I have no idea what temp I am running, I will have to try a mechanical gauge. my fans don't come on until the factory gauge gets into the red zone, and it feels (hand on the upper hose) OK, but I don't trust feel! haha Kickdown is hooked up, might need a little tweak, but it's pretty good. Trans shifts good, now I have third gear at a decent speed, much better! Steering is good, handling not bad, brakes seem OK, all in all it seems pretty drivable.
My issues are the heat- I will have to find out what I'm running at- and my fuel level gauge doesn't seem to work. I still have to get my driver's window functioning properly too. It goes down OK but needs assistance going up... I have a new K&D sender for my water temp, I'm wondering if it's the culprit for my temp readings, maybe it reads too high?? Maybe the voltage stabilizer is off somehow? I'm not sure. I'll have to find out what is up with my fuel level gauge- sender, gauge or wiring... I think I'll remove my PW motor and see if the window goes up and down effortlessly in it's tracks.... I'm guessing it's binding.
I now seem to have weight transfer, maybe too much weight transfer ...? lol it squats dramatically in the rear and the front raises, it still spins but not as much and not as far. It will do a roll-on but only for a few feet usually if it's decent traction available.
I think I will have new rear leafs made. They run about $500 and I can always remove them if they don't help... or make things worse...
Still sorting out the bugs on the car, and finishing my house renos, and and and.... LOL
Body/paint will be next year at the earliest. I have a "rat rod" -ish Jensen until then! *tears*
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224838
08/10/10 06:27 PM
08/10/10 06:27 PM
CrAzYMoPaRGuY
Canada
Here's the muffler I started with.....
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224839
08/10/10 06:28 PM
08/10/10 06:28 PM
CrAzYMoPaRGuY
Canada
This is what we did to them- the only way we could get them to fit in the car.......
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224840
08/10/10 06:30 PM
08/10/10 06:30 PM
CrAzYMoPaRGuY
Canada
I went mandrel bends and very thick collector rings...
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224841
08/10/10 06:31 PM
08/10/10 06:31 PM
CrAzYMoPaRGuY
Canada
Kept it up as tight as possible....
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224842
08/10/10 06:34 PM
08/10/10 06:34 PM
CrAzYMoPaRGuY
Canada
I went with two mufflers at the rear, I think it sounds good but the tips are 4" at the rear- the diameter of the muffler.... I'm thinking of trying a different tip/muffler combo down the road so it looks more like a factory exhaust tip, I love the way these sound but it's a BIG diameter tip....
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#224843
08/10/10 06:39 PM
08/10/10 06:39 PM
CrAzYMoPaRGuY
Canada
Somebody cover Oz's eyes for a second....
CrAzYMoPaRGuY
