Good fuel wate rfilters and seperators kits?
#2243268
01/29/17 05:15 AM
01/29/17 05:15 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
I thought I had a post on this subject in the past but I can't find it now. I'm thinking of adding a better than stock additional fuel filter with a water separator, which brands are good and which ones are not Thanks in advance
Re: Good fuel wate rfilters and seperators kits?
[Re: Cab_Burge]
#2243863
01/30/17 10:50 AM
01/30/17 10:50 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
I thought I had a post on this subject in the past but I can't find it now. I'm thinking of adding a better than stock additional fuel filter with a water separator, which brands are good and which ones are not Thanks in advance If you want to add an additional filter set up, I believe Wix has the head and filters you are looking for. At least they used to, I would add this set up to industrial setups that sat outside and had morons add fuel to the tanks and then leave the fuel cap off. Insurance.
[Re: Cab_Burge]
#2245046
02/01/17 12:13 AM
02/01/17 12:13 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
dieselfuelfiterkits.com has a nice setup. I have installed quite a few and work very well. It comes as a complete kit, and when I say complete, they even give you a tubing cutter to cut your factory fuel lines to install the kit. Uses a Baldwin water separator along with a Cat 2 micron fuel filter. Best thing you can do IMHO to prolong the life of your Commonrail diesel's fuel injectors.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2246155
02/02/17 10:23 PM
02/02/17 10:23 PM
Cab_Burge
I ordered mine yesterday and it arrive today That company use to be here in Bend, OR they are now in Redmond, OR. about twenty miles north. I have looked at a lot of different brands and styles of fuel filters and water seperators in the last couple of months, I liked this one the best Thanks again
