2011 RAM 1500 TRACTION CONTROL #2241822
01/26/17 07:33 PM
01/26/17 07:33 PM
Iowa
Countryside Offline OP
Iowa
I have a TRACTION control issues. I hate it is there any way to completely eliminate it? I know I can poke the button on the dash, but that don't eliminate me from having it engage when the rear end comes around on you. What's the answer also the torque limiter.
Re: 2011 RAM 1500 TRACTION CONTROL [Re: Countryside] #2241894
01/26/17 09:22 PM
01/26/17 09:22 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Hold the button for about 10 seconds, this may completely turn it off, I know on a lot of vehicles it does.
Re: 2011 RAM 1500 TRACTION CONTROL [Re: Countryside] #2241991
01/26/17 11:39 PM
01/26/17 11:39 PM
Iowa
Iowa
I will try it. Hope it works so i don't get stuck anymore.
Re: 2011 RAM 1500 TRACTION CONTROL [Re: WO23Coronet] #2243632
01/29/17 09:58 PM
01/29/17 09:58 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Yes
4wd Lock High , vehicle stopped , hold traction control button for five seconds , should illuminate light within cluster that it is off
4wd Lock Low of course does the same thing under 45 mph
Everything is in the owners manual
Factory tires suck
Just pressing the ESP button only partially disables it. You need to hold it for five seconds while stopped to fully disable it. It will automatically return to partail off when you reach a speed of 40 MPH. This is text from page 391 of the owners manual:
"Full Off
This mode is intended for off-road use when ESP stability
features could inhibit vehicle maneuverability due to trail
conditions. This mode is entered by pressing and holding
the ESP OFF switch for five seconds when the vehicle is
stopped and the engine is running. After five seconds, the
“ESP/TCS Indicator Light” will illuminate and the “ESP
Off” message will appear in the odometer. Press and
release the trip odometer button located on the instrument
cluster to clear this message"
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 2011 RAM 1500 TRACTION CONTROL [Re: Countryside] #2246042
02/02/17 06:30 PM
02/02/17 06:30 PM
Iowa
Iowa
Thanks for the help.
