Rear axle bumpers why are they #224572
02/14/09 03:15 PM
02/14/09 03:15 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
painted or dipped half in yellow paint???See picture. This is off a 71 b body.
Is there a wrong and right way to mount these.
Re: Rear axle bumpers why are they [Re: gygeneral] #224573
02/15/09 01:32 AM
02/15/09 01:32 AM
Ont, Canada
Ont, Canada
No One????
there has to be a reason.....
Re: Rear axle bumpers why are they [Re: gygeneral] #224574
02/15/09 02:19 AM
02/15/09 02:19 AM
Shoreline, Washington
72roadrunnergtx Offline
They are there to prevent direct contact of the axle tube with the frame rails in the event of a bottom out. Not sure why your brackets would have yellow paint on them, the ones on my 72 appeared not to be painted or plated at all. After blasting I painted mine gray.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Rear axle bumpers why are they [Re: gygeneral] #224575
02/15/09 02:22 AM
02/15/09 02:22 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Is it a 440 or Hemi car?
Re: Rear axle bumpers why are they [Re: 1_WILD_RT] #224576
02/15/09 04:28 AM
02/15/09 04:28 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I've seen the yellow paint on BB/Hemi E-Bodies with Dana 60 rear ends.
Re: Rear axle bumpers why are they [Re: Snoopy] #224577
02/15/09 10:35 AM
02/15/09 10:35 AM
London, England
Gavin Offline
Gavin  Offline
London, England
I had the yellow paint on my 71 - original /6 car
Re: Rear axle bumpers why are they [Re: gygeneral] #224578
02/15/09 11:06 AM
02/15/09 11:06 AM
A quick check of the 72’ parts book does show a two different part numbers, one for the Dana equipped b-bodies and one without. Can’t imagine why the brackets would be different, the rubber block is probably taller to due to the larger size of the Dana’s carrier housing. Yellow paint could have been used to denote this change. Do you have a picture of the rubber blocks that were on those brackets?
Re: Rear axle bumpers why are they [Re: 72roadrunnergtx] #224579
02/15/09 11:59 AM
02/15/09 11:59 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Yes...
the paint marking is on the taller stop bumper versions.
The strap has a different step on these, IIRC.
Rick
Re: Rear axle bumpers why are they [Re: RestoRick] #224580
02/15/09 12:04 PM
02/15/09 12:04 PM
Ont, Canada
Ont, Canada
Yes its a 6 pack car with Dana. That must be the reason. I knew you guys would figure it out
I will get a picture of the actual rubber mounts and post it.
Later
Re: Rear axle bumpers why are they [Re: gygeneral] #224581
02/15/09 04:06 PM
02/15/09 04:06 PM
Snoopy Offline
Snoopy  Offline
I pulled these off of eBay.
Left = Standard
Right = HP
Re: Rear axle bumpers why are they [Re: Snoopy] #224582
02/15/09 05:40 PM
02/15/09 05:40 PM
Ont, Canada
Ont, Canada
I just these this afternoon,what was on my car.
According to Snoopy's post, note the difference in the round versus square top
Re: Rear axle bumpers why are they [Re: gygeneral] #224583
02/15/09 05:41 PM
02/15/09 05:41 PM
Ont, Canada
Ont, Canada
And another
Re: Rear axle bumpers why are they [Re: gygeneral] #224584
02/15/09 06:25 PM
02/15/09 06:25 PM
The mentioned e-bay seller’s (Mega Parts) web site has a little more detailed info on their reproduction axle bumpers. Pretty clear the Dana bumper is not only ½’ taller but is generally beefier all around. Anybody have any experience buying from them? Feadback? Thanks for posting the pictures; I picked up a couple of new wrinkles on the brain today.
Re: Rear axle bumpers why are they [Re: 72roadrunnergtx] #224585
02/15/09 08:06 PM
02/15/09 08:06 PM
Ont, Canada
Ont, Canada
Same here, I never would have tought that an axlw bumper could be different.
As far as Mega parts. I've bought from them before, great vendor, had no problems at all.
