Opinions on a complete Cal-trac set up for Duster? #224548
02/14/09 03:06 PM
02/14/09 03:06 PM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
I have a 74 Duster with a mild 360 and would like your opinions of the use of a complete set up of Cal-trac components for front and rear. Would this be a good set up for mainly street use and an a trip to the track occasionally?
If you don't like Cal-tracs, which way would you go and why.
Thanks Gary
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: Opinions on a complete Cal-trac set up for Duster? [Re: twister360] #224549
02/14/09 03:25 PM
02/14/09 03:25 PM
Why would you want to use Cal tracs? Mopar springs and stock axle placement will never wheelhop unlike Ford leaf springs.
I've run a 360 A body as quick as a 1.55 60' on SS springs.
Re: Opinions on a complete Cal-trac set up for Duster? #224550
02/14/09 03:29 PM
02/14/09 03:29 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Lighter weight perhaps. A single mono-leaf will not weigh as much as a pack of leaves, although you may give that up with the traction bar.
Which begs the question, what is the actual weight difference?
I also am curious how these feel and perform on a predominately street car application.
Re: Opinions on a complete Cal-trac set up for Duster? #224551
02/14/09 06:20 PM
02/14/09 06:20 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Don't think I'd spend the $$ if this was just a street and occasional strip car - SS springs will work just fine. But if you are building a serious torque monster or need every bit of E.T. from your leaf spring car then the Cal Tracs are the way to go.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: Sixpak] #224552
02/14/09 07:09 PM
02/14/09 07:09 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Or if you don't want the rear of the car to sit a foot higher than the front.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: MoparJoe] #224553
02/14/09 08:06 PM
02/14/09 08:06 PM
Houma, Louisiana
Houma, Louisiana
I now have SS springs on the rear and the rear end was in the clouds, added 3" lowering blocks and I'm back to normal ride height. I also have a second hand set of competition engineering 3 way adjustable shocks on all 4 corners. I just wanted to know if I could improve on this set up by replacing with the Cal-trac system. I checked with Calvert racing and the entire set up would be $953.00 plus shipping. The Cal-tracs would have to be real superior to shell out that kind of dough is this crappy economy. I have my shocks set in the middle range. Is this correct? Thanks for the help.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: twister360] #224554
02/14/09 08:55 PM
02/14/09 08:55 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
What does the car ride like now? How is the traction?
Re: Opinions on a complete Cal-trac set up for Duster? [Re: NTOLERANCE] #224555
02/14/09 10:14 PM
02/14/09 10:14 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I wouldn't spend that kind of money on a car that runs 13's. There are much less expensive alternatives and ways to get the SS springs so the car isn't sky high. Flip the spring hangers over. I remember one suggestion of B body SS or the 2800# springs on the A's.
I know Sloan swapped out from SS spring to Cal tracks and the car made a big difference in 60' and the way the car left the line. Nice and level, no more left wheel high, car sit level now. It does run mid 10's so the comparison to your car isn't the same.
I don't run SS springs on anything I own.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: NTOLERANCE] #224556
02/14/09 10:17 PM
02/14/09 10:17 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
In my humble opinion.. I would never use SS springs unless the car was strip only..
A couple of years ago, I researched Cal Tracs vs SS springs, I spoke with several of the racers over on the Unlawful race board, I read as many of the old threads that I could find and the majority of the seasoned racers recommends the Cal Tracs. They are easy to install, they offer a smoother ride, they are adjustable for different levels of bite. They are affordable and best of all, they look pretty cool sitting under the car..
With the SS springs, the only advantage to them are the stiff, firmer rider and as said above, will raise the back end of the car.. So if you're looking for that old school 70's look, then SS springs is what you want.. if you're looking for softer ride with a lower more modern stance and something you can adjust for going straight or racing on a course.. Then Cal Tracs is the answer..
Yeah, I'm glad I went with the Cal Tracs
Re: Opinions on a complete Cal-trac set up for Duster? [Re: Jeepmon] #224557
02/14/09 10:38 PM
02/14/09 10:38 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought the Mancini SS springs for my 63 and it sits just right. Don't know who makes them but my ride height came out just right. I agree Caltracs are the best for the most et but my 63 is a street car with a few trips to the track each year and it's not worth the money to me to buy the Caltracs as I am not worried about getting every last tenth out of my car. Ron
Re: Opinions on a complete Cal-trac set up for Duster? [Re: NTOLERANCE] #224558
02/14/09 11:36 PM
02/14/09 11:36 PM
Houma, Louisiana
Houma, Louisiana
The ride is somewhat stiff and the traction with the MT ET street radials is excellent.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: twister360] #224559
02/14/09 11:47 PM
02/14/09 11:47 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
aviater pic is with 002 - 003 springs
this pic is caltrac setup
1.39 9.85 - 137 mph
Re: Opinions on a complete Cal-trac set up for Duster? [Re: Ari440] #224560
02/15/09 12:15 PM
02/15/09 12:15 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If it is mainly a street driven car I would not do a Cal-Trac setup just because street driving will beat up the parts, as will moisture and dirt.
For the money I would use just a set of ESPO heavy duty springs and a pair of Lakewood slapper bars. My Valiant went 1.56 in the 60' and a 12:00@110 on Lakewood clamp-ons and ET Streets.
You could not give me a set of SS springs, but that's just me.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: slantzilla] #224561
02/15/09 02:30 PM
02/15/09 02:30 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Dennis, you are by far more experienced than I am.. but with all due respect.. what parts are you talking about?
Re: Opinions on a complete Cal-trac set up for Duster? [Re: slantzilla] #224562
02/15/09 02:36 PM
02/15/09 02:36 PM
Kirkland, Washington
Pacnorthcuda Offline
And prepare for the "Slapper bars on a Mopar??? " wherever you go.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: Jeepmon] #224563
02/15/09 02:46 PM
02/15/09 02:46 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Rod ends and the aluminum spring eye bushings. The steel sleeves will oblong the holes from dirt. The rod ends will also rust into the bars if you do not keep them well lubed.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: Pacnorthcuda] #224564
02/15/09 02:48 PM
02/15/09 02:48 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Believe it or not, the only place I have ever heard that wad of crap is from a select few on this board.
Re: Opinions on a complete Cal-trac set up for Duster? [Re: slantzilla] #224565
02/15/09 02:51 PM
02/15/09 02:51 PM
I had Lakewood bars on a 70 'Cuda back in the 90s'
I heard it MANY times. Long before Moparts
Re: Opinions on a complete Cal-trac set up for Duster? [Re: Pacnorthcuda] #224566
02/15/09 03:39 PM
02/15/09 03:39 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
The new superstock springs that you buy now are made in Mexico and are junk compared to the old ones. We have cal tracs on the Duster 12.40's and on my Coronet 10.20's and they are both street driven. No lowering blocks,no slapper bars for us
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Opinions on a complete Cal-trac set up for Duster? [Re: 67HEMI] #224567
02/16/09 09:16 AM
02/16/09 09:16 AM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
Not to mention the lean or sagging set that SS springs take, don't they need to be replaced after a few years anyways?And now they are heche in mexico...nice!
I had switched out the SS to cal-tacs on my 65 B-Body, I got the car to sit low (I prefer that look )without using lowering block (which tend not to help traction) it moved pretty good with the 4 speed on the street.
If you search around you can find the parts needed much cheaper than the price you stated, someone had the bars and springs for sale around 500 bucks on Moparts.
And yes, any performance car will need a little more maintenance but isn't that part of the fun of owning something old and fast?
Now lets talk about slapper bars and Mopars, what are you making a Blade Charger replica?
Big Anthony ANTHONYinIRAQ@gmail.com
1984 B150 Ram Wagon
1978 D100 ClubCab
