What water addititive for leaky Cometics ? #224526
02/14/09 02:56 PM
02/14/09 02:56 PM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
What are you guys using for leaky cometics? I have a small leak between the 3 and 5 cylinder. This is my first go around with cometics so i don't really know what to use. Thanks, Jesse
82' dodge pickup with a 499 low deck
Re: What water addititive for leaky Cometics ? [Re: JesseR] #224527
02/14/09 03:17 PM
02/14/09 03:17 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
My W5's did the same thing once I got a few heat cycles in, it stopped leaking.
Is this a new build I hope?????????
I have had sucess with the Moroso ceramic engine sealer it will seal up anything
Re: What water addititive for leaky Cometics ? [Re: JesseR] #224528
02/14/09 03:22 PM
02/14/09 03:22 PM
Mississippi Gulf Coast
Mroctober Offline
Mroctober  Offline
Just get some K&W Block sealer!! Just water in Block it will Stop Leaking
Re: What water addititive for leaky Cometics ? [Re: 340RICK] #224529
02/14/09 03:26 PM
02/14/09 03:26 PM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
Yes, it is a new build with W5's also. I've only heat cycled it a few times, but it didn't start leaking unitl the last time a run it. I'm shooting fro a test and tune next weekend so a hope i can get it fixed.
Re: What water addititive for leaky Cometics ? [Re: JesseR] #224530
02/14/09 05:11 PM
02/14/09 05:11 PM
Canada
lenweiler Offline
lenweiler  Offline
Canada
My W5's leaked before I even fired the engine. No gasget sealer. It stopped leaking after about 2-3 minutes running. Not uncommon. They stopped leaking before I gave it the sealer treatment........
Damn! I dropped my change.............
Re: What water addititive for leaky Cometics ? [Re: lenweiler] #224531
02/14/09 05:19 PM
02/14/09 05:19 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I added a bottle of Bar's Stop leak...That did the trick..
Re: What water addititive for leaky Cometics ? [Re: 340RICK] #224532
02/14/09 05:28 PM
02/14/09 05:28 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
x 2..my current block has been decked ALOT....i had all sorts of issues with head gaskets not sealing,$220 SCE titan head gaskt....leaked..1 treatment of the ceramic sealer and it sealed..make sure to follow directions on the container..it will seal.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: What water addititive for leaky Cometics ? [Re: JesseR] #224533
02/14/09 05:58 PM
02/14/09 05:58 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
This is one of many threads on preping the Cometics.
https://board.moparts.org/ubbthreads/show...e=9#Post5016854
Do a search and you will find the required deck finish also.
Damon
Re: What water addititive for leaky Cometics ? [Re: mopardamo] #224534
02/14/09 06:14 PM
02/14/09 06:14 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
prestone make a sealer that looks like baby spew but it seals real well. can't think of the name of it but it gets my thumbs up
Re: What water addititive for leaky Cometics ? [Re: rebel] #224535
02/14/09 06:18 PM
02/14/09 06:18 PM
since nobody has asked yet, have you backed off one bolt/stud at a time and retorqued them yet. often times that solves the problem. what was the torque # you used initially and what kind of block?
Re: What water addititive for leaky Cometics ? #224536
02/14/09 07:37 PM
02/14/09 07:37 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
My W5s leaked on start up . used barrs leak , sealed good, seems when you drain system you will need the barrs leak again,
Re: What water addititive for leaky Cometics ? #224537
02/14/09 08:39 PM
02/14/09 08:39 PM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
Yes, i've retorqued the studs and i'm at 90lbs with them. This is on a stock 340 block, with super smooth finishes on both the heads and block, we also drilled the rivets and sprayed coppercoat between the layers and used silicone around the water jackets. I was really hoping not to add anything, but i guess i have to. Funny thing though, they only leak when the car is running, not when the engine is cold. Thanks for the help guys, Jesse
Re: What water addititive for leaky Cometics ? [Re: JesseR] #224538
02/15/09 11:40 AM
02/15/09 11:40 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
On my 340 I followed the smooth surface,loosen & retourqe,& rivet clearance. I had a leak on start up. I used some Unnamed Autozone sealer. 3 years ago street & race, high engine temps in traffic, no water loss. I agree the Moroso sealer is the best. I have had it seal 6" long crack in the side of my 440 block for over 3 seasons of racing. no drips, no water loss.
Doug
Re: What water addititive for leaky Cometics ? [Re: Bob_Coomer] #224539
02/15/09 11:55 AM
02/15/09 11:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats all I use... I give every rebuild a bottle
even before I fire it up
Re: What water addititive for leaky Cometics ? [Re: MR_P_BODY] #224540
02/16/09 08:17 PM
02/16/09 08:17 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
just wondering if you tried anything yet??, im in the same boat, very small leak on the outside of the block
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: What water addititive for leaky Cometics ? [Re: Stroker Scamp] #224541
02/16/09 11:11 PM
02/16/09 11:11 PM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
not yet, picked up a can of bars leak today, just not had time to put it in, Jesse
Re: What water addititive for leaky Cometics ? [Re: Stroker Scamp] #224542
02/16/09 11:17 PM
02/16/09 11:17 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Some of the later versions have the slotted steam hole towards the top between middle cylinder instead of a round hole, this slot protrudes outside the enbossment on the cometic causing a leak. i've got two sets like this one i have had welded up,i had a pic but cant find a good one now.
Re: What water addititive for leaky Cometics ? [Re: JesseR] #224543
02/16/09 11:39 PM
02/16/09 11:39 PM
pacific northwest
pacific northwest
well then ill pick up the moroso and we'll do a test, wont fire it for a couple of days,,,,,,,ps im gonna clean everything up from below to better see if its leaking
Re: What water addititive for leaky Cometics ? [Re: Dustedu] #224544
02/17/09 05:49 PM
02/17/09 05:49 PM
Mountain City, TN
JesseR Offline OP
JesseR  Offline OP
Mountain City, TN
That's interesting, i did not pay attention to that, my heads are a later casting so i bet they are slotted, thanks for bringing that to my attention, Jesse
Re: What water addititive for leaky Cometics ? [Re: JesseR] #224545
03/19/09 10:26 PM
03/19/09 10:26 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
What did you find?
