Re: Shopping for a new radiator
[Re: mopar dave]
#2244024
01/30/17 04:01 PM
01/30/17 04:01 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Lots of good radiators out there these days. Summit Radiators were made by Norhtern radiator last I knew?!? Champion seems to have a good reputation and has direct fit for Mopars. IMO side tanks and cross flow works better than a down flow, top tank radiator does.
[Re: mopar dave]
#2244121
01/30/17 06:31 PM
01/30/17 06:31 PM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
i use an AFCO , you do have to tig on your own brackets . been in for about 8 years no worries , daily driver and strip use sideflow are less likely to block up and generally are lower profile .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: mopar dave]
#2244151
01/30/17 07:17 PM
01/30/17 07:17 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I wanted the 1970 mopar radiator look in my car and not the generic GM looking or Scirocco style radiator in my car. SUPERIOR RADIATOR here in Michigan custom made mine to support 1000 streetable horsepower with dual electric fans. I am very happy with it so far.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mopar dave]
#2244160
01/30/17 07:31 PM
01/30/17 07:31 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I bought a champion for my 65 last year.150 shipped from Ebay/Fit was good cools great/i was leary as my OE rad worked great.More than happy with it.Even in the 90s it cools as good or better than factory.only thing had to make new upper hose and use a 1 3/4 adapter to 1 1/2 on lower.That was like 7 bucks.Very happy with it so far.Rocky
Chrysler Firepower
[Re: mopar dave]
#2244292
01/30/17 10:24 PM
01/30/17 10:24 PM
Posts: 4,457 Washington
madscientist
Washington
The EPC is a nice radiator. As long as you don't care if it fits.
I was told it was bolt in...just check the print. I did and the print show the holes in the correct location to each other. They just don't line up correctly car.
So if you don't mind drilling some holes it's a nice piece. Just pisses me off I had to drill holes. They don't put the core in the correct location.
[Re: madscientist]
#2244331
01/30/17 11:13 PM
01/30/17 11:13 PM
dartman366
Mt. Vernon, Ohio
I just bought a Jeg's house brand 28"wide X 19"tall X 3" thick, 2 row 1" cores for mine, be here tomorrow.134.63 with my racer discount, got to make my own mounts tho.
[Re: mopar dave]
#2244395
01/31/17 12:21 AM
01/31/17 12:21 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Looks like a few options here. So far what i have researched 2 row and make sure both rows are 1" wide. Some are not. I want the 2 row Should save me 25 lbs,,,,,,
[Re: mopar dave]
#2244476
01/31/17 02:10 AM
01/31/17 02:10 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Those look to be very nice. I am leaning toward a downflow radiator as well. I noticed something a while back with my howe crossflow radiator. I had the cap off radiator and moroso pump running while watching coolant flow. The top 3 rows had no coolant running thru them at all. Coolant level will always be lower while running pump, so wouldnt a downflow make more sense as all the cores would be full all the time. That's why I suggested the duel or triple cross flow radiators. The water flow will find its shortest path. With Gravity assistance the Down flow rad will more easily find a shorter path vs a Cross flow rad. Witch means it Wont utilize the full surface area of the rad. So the cross flow will cool better, but the water will find its shortest path. Therefore, a forced duel flow or triple flow will cool better. But, with the proper fan cfm flow assist, any of the above rads will work.
[Re: Sport440]
#2244497
01/31/17 02:46 AM
01/31/17 02:46 AM
madscientist
Washington
Those look to be very nice. I am leaning toward a downflow radiator as well. I noticed something a while back with my howe crossflow radiator. I had the cap off radiator and moroso pump running while watching coolant flow. The top 3 rows had no coolant running thru them at all. Coolant level will always be lower while running pump, so wouldnt a downflow make more sense as all the cores would be full all the time. That's why I suggested the duel or triple cross flow radiators. The water flow will find its shortest path. With Gravity assistance the Down flow rad will more easily find a shorter path vs a Cross flow rad. Witch means it Wont utilize the full surface area of the rad. So the cross flow will cool better, but the water will find its shortest path. Therefore, a forced duel flow or triple flow will cool better. But, with the proper fan cfm flow assist, any of the above rads will work. I looked into the double and triple radiators. I passed on them. I'm not smart enough to get all the science but I know the longer the flow path the less flow. If the tubes are big enough it will cool with out passing through the radiator more than once.
[Re: madscientist]
#2244517
01/31/17 03:19 AM
01/31/17 03:19 AM
Sport440
Canton, Ohio
Those look to be very nice. I am leaning toward a downflow radiator as well. I noticed something a while back with my howe crossflow radiator. I had the cap off radiator and moroso pump running while watching coolant flow. The top 3 rows had no coolant running thru them at all. Coolant level will always be lower while running pump, so wouldnt a downflow make more sense as all the cores would be full all the time. That's why I suggested the duel or triple cross flow radiators. The water flow will find its shortest path. With Gravity assistance the Down flow rad will more easily find a shorter path vs a Cross flow rad. Witch means it Wont utilize the full surface area of the rad. So the cross flow will cool better, but the water will find its shortest path. Therefore, a forced duel flow or triple flow will cool better. But, with the proper fan cfm flow assist, any of the above rads will work. I looked into the double and triple radiators. I passed on them. I'm not smart enough to get all the science but I know the longer the flow path the less flow. If the tubes are big enough it will cool with out passing through the radiator more than once. Just saved this for more discussion.
[Re: mopar dave]
#2244653
01/31/17 01:34 PM
01/31/17 01:34 PM
Al_Alguire
Las Vegas
Pretty typical from a crossflow radiator. Likely not filled completely filled to begin with. We fill them under a vacuum or run them pump a few times to make sure they are filled. Also check them after first heat cycle. Some of the OE ones can be a real bear to get full...
[Re: mopar dave]
#2244683
01/31/17 02:19 PM
01/31/17 02:19 PM
Posts: 4,975 new jersey usa
11secdart
new jersey usa
I have had a smsll Nissan radiator in my Dart for many years however for some reason my new 408 does't like it and it runs hot. I bought a Champion from Summit it fit nice and the car runs much cooler it was a good price around $200
[Re: mopar dave]
#2244704
01/31/17 02:54 PM
01/31/17 02:54 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have a big Griffin radiator in the cuda. Bolted right in and works great, but it was expensive. It's a down flow w/ two rows of 1.25" tubes. The Champion radiators that a guy sells in the classifieds here on the board I hear work good, and they're cheap too.
[Re: mopar dave]
#2245400
02/01/17 04:52 PM
02/01/17 04:52 PM
madscientist
Washington
I have to make a correction about the double pass radiators. There are no issues in plugging like I was told earlier. Just spoke with two radiator companies and they both recommend double or triple pass for my app. Tripple pass requires bigger pump like a 55. No off the shelf available. must be custom 1.25" double row double pass. I also have an option of a 1.25" tube double row down flow. I plan on using a mechanical pump and good flex fan with a shroud. I have a fan that moves a ton of air. Before you buy anything,I would google Stewart water pumps and read the stuff on their site. Then call them and ask them what they think of multiple pass radiators. They are not fond of them. Cooling is about total flow and cooling area. If you have to make the coolant travel a longer path to cool the radiator is too small. The EPC is a 2 core with 1 inch cores. With the right water pump and the correct water pump speed that will cool 750 HP easy.
[Re: mopar dave]
#2245411
02/01/17 05:22 PM
02/01/17 05:22 PM
madscientist
Washington
That web page is stewartcomponents.com
A double pass radiator requires 16 times the pressure as a single pass to flow the same amount of coolant IIRC. A triple pass needs 64 TIMES the pressure to get the same flow as a single pass radiator. You need to look it up and read it for yourself.
It made me think differently about cooling than I had before.
[Re: madscientist]
#2245428
02/01/17 06:00 PM
02/01/17 06:00 PM
Posts: 1,845 Tampa
DusterDave
Tampa
My advice is, don't buy into the sales hype of 3 and 4 row radiators. Two rows will cool better. If you need more cooling, get one with 1.25" tubes. And install a sealed fan shroud that covers the entire fin pack!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: mopar dave]
#2245471
02/01/17 07:39 PM
02/01/17 07:39 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I have an ECP 26" core in my 68 Charger 512ci with AC & I am in South east Texas, in 107 outside temp with AC on car runs 185ish all day long, I had a 4core Champion that did not work so well in the same car.
[Re: madscientist]
#2245566
02/01/17 10:23 PM
02/01/17 10:23 PM
Sport440
Canton, Ohio
Checked the site out for myself. They definitely need a new fluid dynamics engineer. To toss out those Two numbers randomly 16 and 64 TIMES is insane. To many variables. If you were trying to pass the Whole Engines water system through a Heater Core, single, dual, triple, pass then it May be closer to the truth. But the newer rads have a lot more flow capacity. But with that said, Yes, the dual; and triple pass rads will have more flow restriction, but Not Nearly the amount, the Stewarts web site suggests. But, I will back peddle a little, the standard newer rads if big enough and with the right shrouds and fans are plenty enough to cool a lot of our rides. Lack of shrouds and fan placement is probably the biggest issues of poor cooling. Dave, my Howe crossflow rad is a 19 x 31 for my A body. Had to trim some excess sheet metal from the driver side frame rail, and make a pocket in the passenger side front portion of the frame rail for it to slide in. So if your up for some miner fabrication you can go bigger on the rad.
[Re: mopar dave]
#2245569
02/01/17 10:26 PM
02/01/17 10:26 PM
madscientist
Washington
Did you put that 28" with in an A body? Curious to how well it fit. How big are the tanks? I bought the 26 inch ECP for an A body. If you go by the print on their site it should all fit. You know, bolt it. But, where they put the core relative to the brackets makes it so you have to modify the brackets and I had to drill some holes in the core support, which I didn't want to do. But for the money I decided that I could use the 2 top holes and put 2 small holes in the core support. For the money you just about can't beat the ECP. I don't trust much of what frank at ECP says about fitment (which is why he will tell you measure everything and compare it to his print) but other than that, it's a nice piece. All that said, if you don't mind doing some minimal mods to the brackets and core support its probably the best for the money. Also, I'd say use the biggest flowing mechanical water pump you can buy and you should be pooping in the tall cotton. One last thing...I bitched like crazy because the overflow hose points to the drivers side and not the passenger side. It's is on his drawing like that, but it was the ONE thing I didn't look at close enough. I've personally never seen an OE Chrysler radiator with the over flow pointing to the drivers side. I just put a loop in the hose to the over flow tank.
[Re: Sport440]
#2245572
02/01/17 10:28 PM
02/01/17 10:28 PM
madscientist
Washington
Checked the site out for myself. They definitely need a new fluid dynamics engineer. To toss out those Two numbers randomly 16 and 64 TIMES is insane. To many variables. If you were trying to pass the Whole Engines water system through a Heater Core, single, dual, triple, pass then it May be closer to the truth. But the newer rads have a lot more flow capacity. But with that said, Yes, the dual; and triple pass rads will have more flow restriction, but Not Nearly the amount, the Stewarts web site suggests. But, I will back peddle a little, the standard newer rads if big enough and with the right shrouds and fans are plenty enough to cool a lot of our rides. Lack of shrouds and fan placement is probably the biggest issues of poor cooling. Dave, my Howe crossflow rad is a 19 x 31 for my A body. Had to trim some excess sheet metal from the driver side frame rail, and make a pocket in the passenger side front portion of the frame rail for it to slide in. So if your up for some miner fabrication you can go bigger on the rad. Is that 19 X 31 a 26 inch core? I don't run a shroud. The fan is close enough to the radiator to not need one.
[Re: mopar dave]
#2245577
02/01/17 10:31 PM
02/01/17 10:31 PM
dartman366
Mt. Vernon, Ohio
Did you put that 28" with in an A body? Curious to how well it fit. How big are the tanks? between the frame rails it is 29" with the lip removed at the top of the rail, the core is approx 1/2 wider ( 1/4" per side) than the opening, that a is un cut core support opening and it was a origional slant 6 car if that makes a difference in the core support, the one I ordered was 555-52018, the info says Ford but it is Ford/Chrysler and also it has NO trans cooler built in but does have a bung for a drain petcock, I am building upper and lower mounts like I have done for the other one that was in the car I think side mounts could be made also.
[Re: madscientist]
#2245586
02/01/17 10:44 PM
02/01/17 10:44 PM
Sport440
Canton, Ohio
[quote=Sport440][
I don't run a shroud. The fan is close enough to the radiator to not need one. The actual core 18.5 x 28 The 31, is to the outside of the cross flow tanks. And IMO, doesn't matter how close your fan is to the rad, It could benefit from a shroud.
[Re: mopar dave]
#2245616
02/01/17 11:26 PM
02/01/17 11:26 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
I have a brand new A body/small block ECP radiator with dual fans and controller I'd be willing to sell. No coolant went through it. Didn't work for my particular application (don't ask, nothing to do with the radiator) so I ended up going back to my old rad and modified that instead of cutting up a new one. I was gonna send it back but never did, just sitting in my garage. ECP rad. Fan controller
'71 Duster '17 Ram 1500
[Re: mopar dave]
#2245684
02/02/17 12:52 AM
02/02/17 12:52 AM
madscientist
Washington
Anyone have a linc to the guy that sells champion radiators on here. Cant find his ad. I didn't think the champions were cross flow. If you google champion radiators he comes up. IIRC he's in California.
[Re: mopar dave]
#2245686
02/02/17 12:55 AM
02/02/17 12:55 AM
madscientist
Washington
I just googled it and couldn't find him.
[Re: mopar dave]
#2245701
02/02/17 01:31 AM
02/02/17 01:31 AM
RMCHRGR
Spahn Ranch
There is a Griffin cross flow for sale in the race parts classifieds...
[Re: mopar dave]
#2245799
02/02/17 10:46 AM
02/02/17 10:46 AM
RMCHRGR
Spahn Ranch
Sorry if I missed it but what is the application here? Guessing big block A body?
[Re: mopar dave]
#2245871
02/02/17 01:34 PM
02/02/17 01:34 PM
madscientist
Washington
I'm alittle afraid of that one all thou I'm not totally afraid of the double pass with 55 gal water pump. I'm currently waiting for a price from champion on a double pass just to see. its just so tempting to get a $150 crossflow, which might be enough. I'm not a big fan of the cross flow and like I said, not a big fan of the multiple pass radiators. Stewart may not have been totally correct with the 16 times more pressure number but I'd bet it's not that far off. You don't need pressure to cool the engine you need flow. Making the coolant travel further decreases flow. That is always bad. Just hate to see you spend your money twice. I'd call some coolant people and see what they say.
[Re: mopar dave]
#2245926
02/02/17 02:59 PM
02/02/17 02:59 PM
Posts: 1,696 central il.
second 70
central il.
I had a 22" factory radiator in my 70 426 hemi cuda that would creep up in warm weather and traffic and replaced it with a 22" 3 row champion and it stays cool now. Fit was good only had to drill 1 lower hole. Mike
[Re: mopar dave]
#2245984
02/02/17 04:54 PM
02/02/17 04:54 PM
madscientist
Washington
I was just looking and measuring the area I have for a radiator. I have a lot of moving stuff around to fit a large cross flow in there. trans cooler and lines will have to be moved. It would be easiest if I could make a down flow work. Who is wizard? Down flow will work very well. If your core support was for a 22 inch radiator you will have to cut it up a bit to get a 26 inch in there. You are always better off with the biggest radiator you can fit in there.
[Re: mopar dave]
#2246362
02/03/17 04:03 AM
02/03/17 04:03 AM
madscientist
Washington
Wizard cooling. Good products but a little more expense. Be careful. That wizard radiator is the EXACT same radiator as the ECP. EXACTLY the same just more money. It is the exact same drawing. It even has the overflow going the wrong way just like the ECP.
[Re: mopar dave]
#2246490
02/03/17 01:38 PM
02/03/17 01:38 PM
madscientist
Washington
looking at the pictures I thought the very same thing. I'm gonna call them in a bit here just to pick there brain. A friend of mine has a wizard in a dart with a 440 SB and he cant say enough good about it. hes very happy. It is a 2 row down flow. Check it out and see what they say. The Wizard is more than double the price for what appears to be the very same thing from EPC. Your friend may be pissed when and if he finds out he could have paid less than half for the same thing. FWIW and IIRC there are very few companies actually building aluminum radiators. Most of these guys are buying kits from China and are welding them up. Some even have the balls to say made in USA on the stuff. Some stuff is China made China welded. Always verify and cross check everything and everyone.
[Re: mopar dave]
#2246703
02/03/17 06:30 PM
02/03/17 06:30 PM
madscientist
Washington
just got off the phone with wizard. They think they can get it done with a 22" core down flow but with 1.25 tube upgrade. They are probably right about that. It would make it easier to mount if the car has a 22 inch core support rather than try and cut and for a 26 in there. Bigger tube is always better. How much is the rad with the upgrade.
[Re: mopar dave]
#2246973
02/04/17 01:46 AM
02/04/17 01:46 AM
hemi-itis
just got off the phone with wizard. They think they can get it done with a 22" core down flow but with 1.25 tube upgrade. How much??
[Re: mopar dave]
#2247049
02/04/17 04:19 AM
02/04/17 04:19 AM
Sport440
Canton, Ohio
I have one now and i was not that impressed. Fittings are on wrong sides. For sale with an electric fan. The ecp was 500 with the 1.25 tube up grade. Fittings on the wrong side?? Well order the correct rad from them with the fittings on the correct side. My tubes are like 1", maybe 1.25" didn't measure them. No upgrades here. From the looks of the ECP and the Wizard, they look equally cheap as well. No way, I'm paying $600 for any of those. Other posters stated they are exactly the same rad.???? Glad you haven't bought anything yet. Your doing Good by doing your research.
[Re: madscientist]
#2247060
02/04/17 05:30 AM
02/04/17 05:30 AM
Sport440
Canton, Ohio
[Re: cdwmotorsports]
#2249273
02/07/17 08:05 PM
02/07/17 08:05 PM
madscientist
Washington
That's what I have. It's. To bolt in for sure, but for the money it's pretty nice. And it pisses me off the overflow hose comes out the wrong direction but it is what it is.
[Re: mopar dave]
#2249331
02/07/17 09:45 PM
02/07/17 09:45 PM
madscientist
Washington
I will have to do some trimming to get that to fit. They recommended there 22" with the 1.25" tube up grade. Think this bigger radiator would be just as good? Its about $300 less. I'm sure someone can do the math but it's probably close. I have cooled 550 HP engines on a stock 26 inch radiator in desert heat. That had just 2 half inch cores in it. And, that particular engine had the cast iron water pump (talking small block stuff) which isn't as good as a Milodon water pump. So I know a two .500 core will easily cool 550 HP if everything else is correct. And that engine had about 1 1/2 inches of filler in it. Whatever just over the top of the core plugs is. And that is a copper radiator. Most people say aluminum cools better than copper.
[Re: mopar dave]
#2249340
02/07/17 09:59 PM
02/07/17 09:59 PM
Sport440
Canton, Ohio
I think it would probably be better then the smaller rad. It has a trans cooler as well. My Howe doesn't have that. It sure is Heavy though at 45#, not sure that's not a typo, but it does include a tranny cooler in the tank.
Love the price, I'm sure you can get that to fit. As per my earlier post, I fitted one bigger in size..
[Re: mopar dave]
#2588345
12/06/18 11:43 PM
12/06/18 11:43 PM
madscientist
Washington
I would look into Cold Case radiators. The Champion radiators I have seen fit well and seem to work but I'm not a fan of radiators with more than 2 cores.
The ECP radiator I have required some modification to fit. I wasn't thrilled I had to drill holes in my core support but I did it.
The Cold Case radiators are said to be a drop in fit.mi would certainly look into them.
[Re: Kilroy was here]
#2588357
12/07/18 12:06 AM
12/07/18 12:06 AM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I bought the EPC in a 26". Had to do some trimming to fit my A body, but it keeps my 511 with a tall fill 195* most of the time. Highest temp was 205* in 93* humid weather. I fit it with a shroud from jegs and use a mechanical fan. Works great and would buy again.
#2589357
12/09/18 02:28 PM
12/09/18 02:28 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
This will be my new radiator in the spring. Ever since I put the 4.10 gears in the car it runs hot on the highway with the increased RPM's Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
