Challenger S/E vinyl top molding clips OEM vs Repro ?? #2235774
01/17/17 01:03 AM
01/17/17 01:03 AM
So Cal
autoxcuda Offline OP
So Cal
I have a wide S/E vinyl top set with 9 original clips.
I see the repro clips don't look at all like the original ones I have. Repro are the S-type spring clip.
Do the repro clips work fine?
Repro
Original
Original
Re: Challenger S/E vinyl top molding clips OEM vs Repro ?? [Re: autoxcuda] #2235779
01/17/17 01:12 AM
01/17/17 01:12 AM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
My car had the clips like the repo you show. I do not believe the top had ever been changed. The repos worked fine on mine.
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: Challenger S/E vinyl top molding clips OEM vs Repro ?? [Re: moparfan] #2235783
01/17/17 01:21 AM
01/17/17 01:21 AM
So Cal
So Cal
Did you clips have a foam seal at the base of the threads?
Did your nuts have sealant (dum-dum) in them?
Re: Challenger S/E vinyl top molding clips OEM vs Repro ?? [Re: autoxcuda] #2235999
01/17/17 01:33 PM
01/17/17 01:33 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
Yes and yes. I put the new on as they came. I figured the car stays inside and will not see weather so it would be fine.
2021 T/A 392
2020 Hellcat redeye
