High Idle when warm for my 360 #223595
02/13/09 06:11 PM
02/13/09 06:11 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
i have a rebuilt 360 with iron heads, 4 barrel carter AFB... it is definitely cold blooded and doesnt want to idle till its nice and warm, but once i get driving and the car is warm if i go into neutral or park the idle jumps to 2000 RPM or so and wont come back down until it goes into drive... whats causing the high idle when warm??... how should i fix it... thanks!
Re: High Idle when warm for my 360 [Re: dakrt23] #223596
02/13/09 06:21 PM
02/13/09 06:21 PM
moparmandc Offline
moparmandc  Offline
is the choke pulling off?
Re: High Idle when warm for my 360 [Re: moparmandc] #223597
02/13/09 06:35 PM
02/13/09 06:35 PM
hooziewhatsit Offline
Yea, make sure the high-idle cam isn't stuck and propping the throttle open.
After that, sounds like the idle needs to be reset. Use the procedure on page 6 here
http://www.edelbrock.com/automotive_new/mc/carbs_acc/pdf/carb_owners_manual.pdf
-Dave
Re: High Idle when warm for my 360 [Re: dakrt23] #223598
02/13/09 10:03 PM
02/13/09 10:03 PM
If you have a factory choke spring mounted on intake manifold make sure the exhaust crossover gets hot.
Re: High Idle when warm for my 360 [Re: dakrt23] #223599
02/13/09 11:33 PM
02/13/09 11:33 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
check your throttle cable,when engine gets hot it may tighten up,happend to me before, same way it happened to you.
