Page 7 of 7 1 2 3 4 5 6 7
Re: Dragweek 2017 Questions [Re: Dart451] #2278918
03/30/17 02:58 PM
03/30/17 02:58 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I would second avoiding the FITech...I don't hate it...but it took a bit of work to get it right, and it's not really better than a tuned carb.
Mine ran reasonably well all last year, after a ton of tuning time, then the spark just quit working...Something seemed to corrupt my cal, and the tech support really leaves alot to be desired. You get what you pay for (Chinese hardware and no support...ha)
here is what I did for a fuel system:
https://board.moparts.org/ubbthreads/ubbt...tml#Post1921168
https://board.moparts.org/ubbthreads/ubbt...tml#Post1939051
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Dragweek 2017 Questions [Re: Dart451] #2279020
03/30/17 06:18 PM
03/30/17 06:18 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I bought a 1200 hp power adder system last spring (was thinking blow thru turbo build) Any experience with that model?
Re: Dragweek 2017 Questions [Re: OUTLAWD] #2279021
03/30/17 06:22 PM
03/30/17 06:22 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Thanks for links.
More fitech user problems not liking the sounds of that. Have to admit its hard to give up the simplicity of a carb
Re: Dragweek 2017 Questions [Re: Dart451] #2279042
03/30/17 07:10 PM
03/30/17 07:10 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I have the 1200HP on my car...not blow through, using it to control N2O.
I have 4-5000 miles on the unit. I have dug into it a bit and modified the VE tables to get it dialed in closer. Any questions feel free to ask
Re: Dragweek 2017 Questions [Re: Dart451] #2279047
03/30/17 07:31 PM
03/30/17 07:31 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I never did the blow thru but was thinking about using it for dragweek with nitrous for drivablitiy. My distributor is locked out, want to use timing control to help with partial throttle
Re: Dragweek 2017 Questions [Re: Dart451] #2279052
03/30/17 07:41 PM
03/30/17 07:41 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
That is the one major benefit, is having timing cranked up to 42 while cruising...it cleaned up part throttle and tip-in.
I would verify your N2O timing retard accepts negative values before you spray it...
Re: Dragweek 2017 Questions [Re: Dart451] #2279082
03/30/17 08:36 PM
03/30/17 08:36 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Has been both the lower and higher HP systems.
For the trouble that they provide if you can afford an aftermarket multiport system it is quite the leap ahead vs the Fitech.
I run 40-44 degrees under light cruise and get it nice a lean. Nice thing about an aftermarket ECU is that you have unlimited control of every parameter vs set values + or -. Then if you get a tuner involved, might as well spend the money towards something that you can get more benefit from.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Dragweek 2017 Questions [Re: Dart451] #2279282
03/31/17 12:53 AM
03/31/17 12:53 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Plan was to keep it simple and be able to swap back to a carb if problems happened.
There is a different engine combo after dragweek that will go multiport.
Might just sell fitech and stay old school, get a more adjustable carb and vacuum advance distributor.
Looking forward to getting car to track for base runs
1st base runs
2st I want to rescale car and get the ride height set and see if 60ft times can be improved
3nd see how bad exhaust changes et
4rd regear for more street friendly check et
5th try fitech? (glad to know there is some help with tuning fitech on moparts)
Also need to rewire car, add passenger seat, bigger fuel cell and trailer hitch, probably rescale car again lol
Re: Dragweek 2017 Questions [Re: Dart451] #2279299
03/31/17 01:16 AM
03/31/17 01:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
1st base runs
I'm still working on my Holley injection.. I
should have it done next week with the help of
Trendz.. I needed a set of pliers to crimp the
small pins on( I didnt have them but will buy
a set)he is loaning a set to me.. once I get the
pins on I will be done with the bulk of the hard
wire stuff.. my crank senor mount will be here
tomorrow and I can get that done(I have the
sensor already).. then just put in the dist sinc
and do the software stuff.. hopefully it'll be
done in a week.. by then I hope the weather comes
around so I can get on the road to test
EDIT
Before I started the coil stuff this engine came
ALIVE.. it revs quicker than it ever has.. I sure
want to see what it does later on.. it sure is way
different.. that was just working on the fuel
wave
Re: Dragweek 2017 Questions [Re: Dart451] #2293989
04/25/17 05:24 PM
04/25/17 05:24 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Got a few test passes in this weekend. Wife loves the transbrake/two step
10.92 at 119.8
Test Pass Passenger Side
Test Pass Driver Side
Re: Dragweek 2017 Questions [Re: Dart451] #2293995
04/25/17 05:37 PM
04/25/17 05:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
10.92 at 119.8
Glad to hear your getting some passes in.. I'm
playing with injection wiring.. still
wave
Re: Dragweek 2017 Questions [Re: Dart451] #2294367
04/26/17 09:26 AM
04/26/17 09:26 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I still need to rewire the whole car so I have lights and signals. Hopefully you get some test hits soon
