Re: Let's see your dashes and gauge layouts
[Re: Hot 340]
#2232066
01/11/17 01:48 AM
01/11/17 01:48 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Wholly crap you guys are busy over there
[Re: Hot 340]
#2232069
01/11/17 02:02 AM
01/11/17 02:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
This is my Rampage.. this was just before I put it in for the final time.. the lights on the upper area are the turn signals and the one bottom is the brights indicator
[Re: Hot 340]
#2232106
01/11/17 03:49 AM
01/11/17 03:49 AM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
Crappy picture but you can get an idea.... 1940 Plymouth......
CrAzYMoPaRGuY
[Re: Hot 340]
#2232215
01/11/17 12:08 PM
01/11/17 12:08 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
'71 Duster street machine. Other than the SW mechanical tach, these are Autometer Traditional chrome gauges. I think thee panel is from Redline gauge works or something like that. A bunch of vendors sell the sme part. It's ABS plastic. Not quite finished yet, need to add turn signal indicators and a few other things. LED shift light where the wiper switch is supposed to be on the lower right. A/F meter on the lower left, not sure if it will stay there, might put it where I can see it better. Helped to clean things up and allowed me to get rid of the redundant stock gauges that were not hooked up or working. Might try to 'finish' the panel a little better before it goes back in.
'71 Duster '72 Challenger '17 Ram 1500
[Re: MR_P_BODY]
#2232428
01/11/17 07:40 PM
01/11/17 07:40 PM
Posts: 3,396 Pa
Hot 340
Pa
This is my Rampage.. this was just before I put it in for the final time.. the lights on the upper area are the turn signals and the one bottom is the brights indicator Digital odometer hooked up? Looks good.
[Re: Hot 340]
#2232447
01/11/17 08:17 PM
01/11/17 08:17 PM
MR_P_BODY
This is my Rampage.. this was just before I put it in for the final time.. the lights on the upper area are the turn signals and the one bottom is the brights indicator Digital odometer hooked up? Looks good. Yes its a digital odometer... thanks.. it looks good after I got it all done.. matter of fact I had the cluster out today then put it right back in.. I was gonna change some wiring but I could get to it easier under the dash
[Re: Hot 340]
#2235513
01/16/17 07:12 PM
01/16/17 07:12 PM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
Here's one I made for my '72 Duster
