Re: Speedometer gear
[Re: stumpy]
#2233682
01/13/17 07:47 PM
01/13/17 07:47 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In my state the painted stripes next to the mile markers are dead accurate...the airborne cops use the stripes to issue speeding tickets so they have to be accurate.
[Re: stumpy]
#2233835
01/14/17 12:03 AM
01/14/17 12:03 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
For the price of a tank of fuel there are millions of smart phones for sale. Obama even gives them away.
Many highways in Calyfornua no longer have mile markers.
Before smart phones, I too used mile markers and a stop watch, that cost me more than a used smart phone costs today. The smart phone has proven more convenient for me and accurate and I ain't required to find no highway to check my speedo or odometer.
Could help OP with his issue.
I recently went thru a speedo accuracy issue with wife's 55 T Bird in which I had swapped in an AOD 4 speed auto transmission. I not only had to sort out mph speedo, but too an odometer accuracy problem. Could have done it with mile markers and a stop watch,,,,but would have wasted a few additional hours doing so over using this app.
60 mph, how long to go 1 mile=
120 mph, how long to go 1 mile=
90 mph, how long to go 1 mile=
[Re: JohnH]
#2233900
01/14/17 04:16 AM
01/14/17 04:16 AM
Sxrxrnr
Northern Calyfornua
As an ex--fireman for the Chicago, Burlington and Quincy Railroad on the head locomotives of very high speed passenger trains such as the California Zephyr as a young man, trains sometimes running over 100 mph(speed limit 87 mph) we were always aware of our speeds.
Using either our RR certified pocket watches(or just introduced in the early 60's, Bulova Acutron wristwatches), we(Engineer or Fireman) were always train speed aware, and often would time our trains using mileposts and watches to check out the accuracy of the diesel locomotive speedometers, as accuracy was paramount.
Using this primitive technology, we would be close enough for government work,,,however if eyeballing your watch or the mile post you always were subject to a 'fudge' factor of several mph being common.
Using modern technology utilizing GPS either via a smart phone app or a Garmin type navigation device you are dead nuts on,,,,and far simpler. Calculate the answers to my 3 questions on mph and get back to me for further information, most who attempt will not have the correct answers.
It is impossible to accurately determine looking at an odometer that when the 10th mile indicator is exactly the same as it was when you started you measurement, however 5 or 10 mile measurement average will dial it in more accurately.
My point being that a GPS device is mandatory if you wish indisputable accuracy, if government work standards are sufficient and you have the time,,,mileposts and wristwatches will certainly do the job.
As for me I would prefer to have purchased and installed the correct speedometer gear on the first attempt.
The reason for suggesting to OP that a GPS device may help him in his quest.
The purpose of this forum is to help our fellow members in offering up opinions,,,,as to the most expeditious solution to problem that is presented
When I proposed a smart phone app to perhaps help him out, never occurred to me thst one should first ax if he had access to a smart phone.
Tough Crowd!
[Re: Sxrxrnr]
#2233957
01/14/17 12:15 PM
01/14/17 12:15 PM
RapidRobert
Tough Crowd! We're the best. yes the mile markers are as accurate as an non electronic system can be but agreed I would borrow a smart phone or something similar. I catch Hell for this. I unhook the wire to disable the ringer at night.
[Re: JohnH]
#2236845
01/18/17 05:51 PM
01/18/17 05:51 PM
Posts: 74 Stevensville, ON
Frank Raso
Stevensville, ON
You can calculate exactly what speedometer pinion gear you need if you know the tire size and axle gears. I went through this exercise when I upgraded my 65 Barracuda to LBP wheels and have a write-up about it. Tire UpgradesWhat size tires do you have on the back?
