Re: Back into it after about 12 years - Need Ebody help
[Re: lostdog]
#2231602
01/10/17 02:03 PM
01/10/17 02:03 PM
Posts: 2,937 GA
roadrunninMark
GA
Steering box mounts to the k frame with 3 bolts. I have a complete pair of front drum brake setup, if you want to go that route.
[Re: roadrunninMark]
#2231609
01/10/17 02:15 PM
01/10/17 02:15 PM
Posts: 361 mississippi
lostdog
mississippi
Steering box mounts to the k frame with 3 bolts. I have a complete pair of front drum brake setup, if you want to go that route. Ok - thanks. If I need the brakes I will get back to you. I appreciate your help.
[Re: Dave Hall]
#2231832
01/10/17 08:39 PM
01/10/17 08:39 PM
lostdog
mississippi
The car will probably never see a track again. I am going to remove part of the cage so I can get in and out of it easier. Replacing the inner fenders will reduce the likelihood of debris getting in the engine compartment because I will be driving the car some on nicer days. I am by no means trying to restore this thing either, not even close. I just want a decent driver for my own enjoyment and maybe a little tire smoke every now and then.
And thanks for the specs on front track !
[Re: Dave Hall]
#2232907
01/12/17 04:01 PM
01/12/17 04:01 PM
lostdog
mississippi
That is one BIG project. A LOT of fun to be had... I hope to have it running, rolling and stopping by mid July. We shall see. I expect I will accumulate quite a few cuts, bruises and dirt in the eye - just like the old days.
[Re: lostdog]
#2271133
03/17/17 01:25 PM
03/17/17 01:25 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes backing plates go in that spot you need complete brake assemblies
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2271141
03/17/17 01:45 PM
03/17/17 01:45 PM
lostdog
mississippi
Yes backing plates go in that spot you need complete brake assemblies Ok - thanks. That's what I was hoping. Now I need to get all the brake parts.
[Re: lostdog]
#2271150
03/17/17 01:55 PM
03/17/17 01:55 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Welcome back, The same thing happened to me. Got "lost" for about 15yrs. Now working on this project, one of three, with my 14yo son [video:youtube] https://youtu.be/iSaYF3Va4RY?list=PLEQmGOZDx8smgrcx3nuaL_WBhYVIgtyfd[/video]
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: NANKET]
#2271220
03/17/17 03:51 PM
03/17/17 03:51 PM
lostdog
mississippi
What is wrong with those axles you have? The plates do not need to be perfectly straight, yours look fine from here.
Look at this picture below, the brake parts are oddball so forget that, but the way the plate mounts is what you should look at, the axle and bearing goes in there and bolts down. Pretty simple. Yes, that's what I was hoping to see. Look in this picture at the red arrow and you can see where a home-job axle shortening was done. It looks like they cut the spline end off, shortened the axles and welded spline section back on. Take note of the yellow arrow which shows the spline section is missing- home shortening fail. There wasn't a chunck in the rear end so it's been exposed to the elements. I can only assume they shortened the housing too which is why I am having it checked
[Re: stat5]
#2476181
04/02/18 04:13 PM
04/02/18 04:13 PM
lostdog
mississippi
I pretty sure both upper and lower radiator support pieces were original spot welded on. As to bolts to attach fenders I would say go to ebay and search e-body fender bolts, you'll find full bolt/clip/stud kits for attached both fenders. Great - thanks! And what about the junction where the top support meets the apron; do you know if it's spot welded there too? I appreciate your help. I had the same idea about the bolts right after I posted this.. I'll be able to find it there. Thank you!
