gettin spark for a second
#2230589
01/09/17 01:51 AM
01/09/17 01:51 AM
Posts: 460 las vegas,nv
mopar muscle7271
las vegas,nv
I have a 71 dart with a 440 factory electronic igination.when i turn the key on i get spark.i will lose spark when the engine is tryin to start.when i let go of the key i kinda have spark again. Possibly the ignition switch or coil?
Re: gettin spark for a second
[Re: mopar muscle7271]
#2230638
01/09/17 04:56 AM
01/09/17 04:56 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
It sounds like one of two things, loose or dirty connection on the ballast resistor or a wiring problem from the ignition switch to the ballast resistor. Someone put that motor and ignition in that car, check all the connection closely first and then use a volt meter to check the voltage (check the voltage at the battery first, if it is around 12.6 volts) to both ends of the ballast resistor, you should have almost the same voltage,12.4 to 12.6 V, at the ballast on one end and around 6.0 to 8.5 volts to the other end with the key on and the engine not running Next thing is to put the shifter in some gear position other than neutral or park and have a helper turn the ignition switch to the start position while you check the end of the ballast resistor that had the lower voltage with the key on, it should increase to battery voltage or a tiny bit less in the start position to that end of the ballast resistor to make the coil fire when in the start position Mopar electrical engineers made it harder on us to trouble shoot problems in their design of theses cars Let us know what you find and have to do to fix it, that will help others on here later
#2230644
01/09/17 05:48 AM
01/09/17 05:48 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
check the air gap on the distributor also...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2230696
01/09/17 11:34 AM
01/09/17 11:34 AM
RapidRobert
5 pin/4 terminal "dual" ballast system or 4 pin/2 terminal "single" ballast system? As said: bad box/open in ballast/too much reluctor gap
#2230703
01/09/17 11:55 AM
01/09/17 11:55 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Since the ballast is bypassed in start and he's only getting spark in run I seriously doubt it's the ballast resistor.
Since you get a spark at all I doubt it is the coil.
Since the ignition switch is what bypasses the ballast I suspect that or the wiring/connectors.
[Re: buildanother]
#2230736
01/09/17 12:38 PM
01/09/17 12:38 PM
RapidRobert
I had that exact same symptom once & it was either the box or the ballast I can't remember which
#2230892
01/09/17 04:42 PM
01/09/17 04:42 PM
Posts: 5,080 organ
maximum entropy
organ
11 out of 10 times it's the ballast resistor...
#2230959
01/09/17 06:15 PM
01/09/17 06:15 PM
Posts: 2,094 central texas
krautrock
central texas
in that case definitely pay attention to ign1 and ign2. one is hot when ign is in start, the other hot while ign is in run. they both need to go to...the coil...or the ign box (in my case my msd) or wherever depending on yr ignition setup. look at a schematic.
#2231013
01/09/17 07:21 PM
01/09/17 07:21 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
OK guys..... look at the original post. If I'm reading it correctly, then he has spark at "run", but no spark at "start" position of the key.
This is the OPPOSITE of the typical ballast resistor burning out. If I'm reading that correctly, then there's either a problem with the brown wire coming out of the bulkhead disconnect (the one that bypasses the ballast resistor) or the ignition switch itself.
One way to test this would be to run a jumper wire from the + of the battery to the disconnected ballast resistor plug that has the brown wire. If the car starts & stays running, then you've found the problem. Don't just leave that wire hooked up though since your ignition voltage is supposed to be "stepped down" with the ballast resistor during normal running & this jumper wire isn't going through the ballast resistor.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Andrewh]
#2231050
01/09/17 08:07 PM
01/09/17 08:07 PM
Supercuda
About to go away
About to go away
up yours
sure. same thing to me. electronic part.
if the key movement is allowing something to happen in the box even though it isn't working, then you won't be able to start the car by bridging the start relay.
if it does start then you have an issue with the circuit that should power the coil/spark box when in start.
it should be pretty quick to see which. The ECU doesn't care if the key is in run or start, it is powered the same regardless. What is powered differently is the coil. So, if the ECU makes a spark at all it is working.
[Re: Andrewh]
#2231179
01/09/17 11:04 PM
01/09/17 11:04 PM
Supercuda
About to go away
About to go away
up yours
sure, but my statement is still good. if he can start it in run then there is a circuit issue. if he cannot, then maybe it isn't the ecu, but something died and has to be replaced. it narrows down this chase. True, but for any test to be useful you have to know what it is doing.
[Re: Supercuda]
#2231207
01/09/17 11:36 PM
01/09/17 11:36 PM
RapidRobert
I'm thinking it might be hard to decipher if it is on "run" or "crank" in that split second when the key is being released from crank to run when there is the one spark. What I would do is pull the yellow wire off of the "ign" terminal on the starter relay to disable the starter (we know it cranks & no need to run the batt down for this testing) and charging the battery up with the alt causes system problems and have a helper hold the key to "crank" & see if the coil positive primary terminal and the blue/yellow ECU terminal is hot (the red/green terminal on an OE 5 pin ECU needs to be hot also) then release the key to "run" & see if everything is still hot. grab your meter.
