Camshaft ID help #2228533
01/06/17 12:34 PM
01/06/17 12:34 PM
MI
74_duster Offline OP
MI
Can anyone help id this camshaft?
I am tearing down a 340 with unknown componets and this is the camshaft in it. Im assuming its a stock style replacement but would like some more info and could not find anything in my searches. measures .436 lift exh .424 on intake.
stamping on end of cam show
C 936
69-04-87
0348 S
if anyone knows anything about the specs or manufacturer i would appreciate it.
Re: Camshaft ID help [Re: 74_duster] #2228704
01/06/17 04:45 PM
01/06/17 04:45 PM
Are you saying the valves opened .424 and .436 or is that the lobe lift work
Re: Camshaft ID help [Re: 74_duster] #2228713
01/06/17 05:00 PM
01/06/17 05:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think thats a Crane cam... I was trying to
look up some numbers from the lobe profile
catalog but I think thats a old cam... I assume
its a hyd flat tappet
wave
Re: Camshaft ID help [Re: 74_duster] #2228855
01/06/17 08:29 PM
01/06/17 08:29 PM
MI
MI
those numbers were valve lift and it is a hyd flat tappet.
When you take off the valve covers and find all the left and right hand rockers on the wrong sides i figured it was time to tear it down and do it right.
Re: Camshaft ID help [Re: 74_duster] #2228862
01/06/17 08:37 PM
01/06/17 08:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would put some fear in ya
You might try calling Crane and see if
those numbers are theirs... or they MIGHT
know who
wave
Re: Camshaft ID help [Re: 74_duster] #2230750
01/09/17 01:12 PM
01/09/17 01:12 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
This is a Crane part number 969361. It's the BluePrinted (computer-smoothed) equivalent of the factory 2899206 hydraulic lifter camshaft that was original equipment in the 275HP 340 cu.in. 4bbl engines. Cam lobe lift is .2861" intake, .2958" exhaust. Gross valve lift with the standard 1.5:1 rockers is .429" intake, .444" exhaust. Lobe separation is 114 degrees. The duration at .050" tappet lift is 210 degrees intake, 221 degrees exhaust. Cam timing at .050" is: intake opens 8 ATDC, intake closes 38 ABDC, exhaust opens 45.5 BBDC, exhaust closes 4.5 BTDC. This particular cam was produced the 4th week of 1987. Regards, Chase
Re: Camshaft ID help [Re: cknight] #2230884
01/09/17 04:24 PM
01/09/17 04:24 PM
MI
MI
cant get a better answer than that. Thanks for the help Chase
