What tire to replace ET Streets? #2230389
01/08/17 09:43 PM
01/08/17 09:43 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Just curious what you guys recommend to replace some 30 X 12.50 X 15 ET Streets? Are the Hoosier Quick Time Pros the next best thing? FWIW, they are going on a 3700lb Roadrunner with an automatic, 3500 stall, SS leaf springs with a 1.68 60' on a good day. They will also see street use. Thanks guys! up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: What tire to replace ET Streets? [Re: MadMopars] #2230419
01/08/17 10:18 PM
01/08/17 10:18 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
315/60-15. Radials
Re: What tire to replace ET Streets? [Re: MadMopars] #2230463
01/08/17 11:13 PM
01/08/17 11:13 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
ive had great luck with qtp's on both my cars. The roadrunner just has old Gtx leaf springs and is absolutely nothing trick. Been a 1.53 60ft & 4000# driving it to the track.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: What tire to replace ET Streets? [Re: Leon441] #2230466
01/08/17 11:16 PM
01/08/17 11:16 PM
Tucson AZ,
Tucson AZ,
Originally Posted By Leon441
315/60-15. Radials
These? work
Mickey Thompson Radials...
Re: What tire to replace ET Streets? [Re: MadMopars] #2230504
01/09/17 12:10 AM
01/09/17 12:10 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
315/60-15. Radials
These? work
That is what I am running now. I was running the old ones but they stopped making them. I broke an axle on the 3rd pass with the new Pros. A best of 1.33 60 ft. so far.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: What tire to replace ET Streets? [Re: MadMopars] #2230782
01/09/17 01:59 PM
01/09/17 01:59 PM
Renton Washington
Triple Threat Offline
Renton Washington
The ET street radial pro is not DOT approved, or recommended, but yes its a great tire.
http://www.mickeythompsontires.com/strip.php?item=ETStreetSS
This is probably more along the lines of what you need with a car that will see some miles. 295/65/15 should work well.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What tire to replace ET Streets? [Re: Triple Threat] #2230810
01/09/17 02:35 PM
01/09/17 02:35 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
The ET Radial Pro certainly is DOT approved. M/T explicitly states it is not intended for street use for liability reasons.
Re: What tire to replace ET Streets? [Re: EV2DEMON] #2230910
01/09/17 05:16 PM
01/09/17 05:16 PM
Tucson AZ,
Tucson AZ,
The 315 ET Street Radial Pro is apparently no joke. After reading this article, I'm thinking they're probably overkill for my application. Still leaning pretty hard towards giving them a shot though. May use them on one of my other cars if they work that well.
Dragzine Article...
