Re: OK Christmas is over, what upgrades have you bought??!!!
[Re: Uhcoog1]
#2224000
12/31/16 01:28 PM
12/31/16 01:28 PM
Posts: 2,432 NorCal
RylisPro
NorCal
18x13 Forglines. Square. Nice Wade! Competition Monoblocks? Which ones?! I am guessing 6-lug? haha! Happy New Years! ![](http://i101.photobucket.com/albums/m69/arielrylis/bluethumb.gif)
[Re: dangina]
#2224001
12/31/16 01:29 PM
12/31/16 01:29 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
bought the holly hydramat that mounts to the bottom of my intank fuel pump for some piece of mind
Which one? The 3"x15" - pn 16-111 - with the 11mm walbro attachment? I am about to buy this one. Any feedback? Do you have in hand yet? Thanks
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: RylisPro]
#2224013
12/31/16 01:39 PM
12/31/16 01:39 PM
Uhcoog1
Houston Tx
18x13 Forglines. Square. Nice Wade! Competition Monoblocks? Which ones?! I am guessing 6-lug? haha! Happy New Years! Happy New Year Ariel! Yes, 6 lug. GW3R (competition 3 piece). I should probably start a build thread (more like refurbish thread- not much fab work required, just bringing a 10 year old racecar up to date).
[Re: Uhcoog1]
#2225127
01/01/17 10:50 PM
01/01/17 10:50 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Which one? The 3"x15" - pn 16-111 - with the 11mm walbro attachment? I am about to buy this one. Any feedback? Do you have in hand yet? Thanks Yep! Emailed Holley and they said that one is a direct fit for the pumps, it's sitting at the border, won't be able to get it for another week, won't be able to put it in at least for two months
[Re: dangina]
#2225179
01/01/17 11:47 PM
01/01/17 11:47 PM
Posts: 670 Los Osos, Ca
CKessel
Los Osos, Ca
If they wrapped it in a burkha, it would get there with no issues.
Carl Kessel
[Re: CKessel]
#2225184
01/01/17 11:50 PM
01/01/17 11:50 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
If they wrapped it in a burkha, it would get there with no issues. YaBetChya. AND it'd have an extra thousand dollars in the pocket from the U.S. government.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: dangina]
#2225245
01/02/17 01:01 AM
01/02/17 01:01 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
DoctorDiff 13" Cobra front brakes. I'll order the rear 11.75's next month to match.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: dangina]
#2225391
01/02/17 10:15 AM
01/02/17 10:15 AM
Posts: 191 NJ
JH23
NJ
I've been working on my winter project and finally got all my Xmas presents. Year One Rally wheels, Nitto 505's, Hotchkis TVS kit, Hotchkis/Fox adjustable shocks, US Car Tool Level II package, March serpentine pullys, Borgenson box and pump, Hydratech, Milodon road race pan, pump, windage tray, Firm Feel sector shaft and roller bearing, Magnaflow stainless, Dr. Diff stage 3 brakes, Autometer tach, speedo, engine gauges, and ALOT of other small stuff.
[Re: migsBIG]
#2227632
01/05/17 09:50 AM
01/05/17 09:50 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Wilwood 13' 6 piston brakes, 11in Wilwood rear brakes, BE&A 1970 Cuda grill, enough paint and supplies to restore two cars, another e-body project and a custom front suspension for one of my cars. Now just have to see if I can get a third job and work the dept away. Nice, I just installed those front brakes and the 12.2" rear kit. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: migsBIG]
#2228108
01/05/17 08:59 PM
01/05/17 08:59 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Cool, that's what was recommended for my type of driving environment. I was thinking of updating the pads they came with, which ones are you using? I'll use the pads they came with until they aren't enough. The car needs to drive under it's own power first.
[Re: dangina]
#2230197
01/08/17 06:33 PM
01/08/17 06:33 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
I decided to do more metalwork on the trans tunnel for Christmas
[Re: ntstlgl1970]
#2230313
01/08/17 08:10 PM
01/08/17 08:10 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
I decided to do more metalwork on the trans tunnel for Christmas Same here... Well, got these before Xmas with clutch/plate, hyd throw out/master. Need to get a bellhousing for it and driveshaft.
[Re: Sxrxrnr]
#2234113
01/14/17 06:19 PM
01/14/17 06:19 PM
dangina
You evidently had one he*l of a big tree.
Watch carefully that Road Race oil pan if you attempt to torque bolts to recommended 15 pounds. You will severely dimple it,,depending on gasket you use.
I ended up building a girdle that encircles the pan of 1/8th thick stock steel that goes between pan and bolt heads. Highly recommended. I believe that someone is now selling a kit.
Do this right, you should not need any of the silicone sealers that inhibits the removal next time. do you know where these kits are sold? I'd love to get one, I've already had to remove my pan 3 times since I got it and the silicone is a PITA to remove, also why hasn't milodon made a reuseable gasket for the big block yet? they have them for the small block...
[Re: dangina]
#2234127
01/14/17 06:32 PM
01/14/17 06:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure why you are using RTV on a BB oil pan gasket. The stock paper gaskets have always worked for me. But here you go: http://www.manciniracing.com/marareoilpan1.htmlUnless you absolutely have to have a Milodon oil pan gasket.
[Re: dangina]
#2234215
01/14/17 08:50 PM
01/14/17 08:50 PM
Posts: 200 Colorado
Bob J
Colorado
Where do you buy the bolt spreader kit for the oil pan.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: dangina]
#2234245
01/14/17 09:46 PM
01/14/17 09:46 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Do this right, you should not need any of the silicone sealers that inhibits the removal next time. do you know where these kits are sold? I'd love to get one, I've already had to remove my pan 3 times since I got it and the silicone is a PITA to remove, also why hasn't milodon made a reuseable gasket for the big block yet? they have them for the small block... Rumor has it that Hughes has em. Forum member jbc426 told me last evening he just bought one. Says looks real fine. Oh yes, he also told me that his Milodon oil pan was dimpled badly when he recently tore his 496 stroker down for a bit of a refresh. That's why he bought the kit. Here's what I built for mine a couple years ago. My Road Race had dimpled, straightened it out, used my little fix, torqued bolts to recommended 15 pounds,,studs at rear main retainer,,,long story here,,,,used no silicone and pan does not leak.
![Name: IMG_0243.JPG
ID: 269968 IMG_0243.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/269968/filename/IMG_0243.JPG) ![Name: IMG_0241.JPG
ID: 269969 IMG_0241.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/269969/filename/IMG_0241.JPG)
