Re: transmission and EFI control for a boosted 6.1
[Re: 5280Dart]
#2226091
01/03/17 01:38 AM
01/03/17 01:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
All I see that the Dominator will run is the GM trans.. I cant help being I'm running the HP unit
[Re: mcat4321]
#2227537
01/05/17 01:10 AM
01/05/17 01:10 AM
Posts: 1,111 tri-cities Washington/Denver, ...
5280Dart
Efisource.com now has a transmission control unit for their gold box
Thanks for the heads up... looks like it is for the GM transmissions only at this point. I will keep it in mind if I dump the NAG1.
[Re: 5280Dart]
#2227559
01/05/17 01:36 AM
01/05/17 01:36 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Check with Bill from Paramount Transmissions. I helped him with his twin turbo Jeep in the early days. He is one of the leading builders of Nag 1 trannies. The guy is a freakin' genius and designs a lot of his own parts. He might be able to steer you in the right direction.
[image][/image]
