Re: New Car Goals and a Crossroads
[Re: A39Coronet]
#2226618
01/03/17 09:44 PM
01/03/17 09:44 PM
Thumperdart
State of confusion
My little 470 BB runs easy 9's, drives great and is a blast on the street Not to thread highjack, but are you assuming 9s, or do you have a timeslip? I agree with the sentiments above, you can never be too safe. I wouldn't count costs associated with a good -5 or better suit, you should have one anyway IMO. Those single layer jackets aren't saving anyone in a fire. Biondo had/is having a killer sale on -5 suites now. I'm not a bser and people on here can vouch for me I'm sure...............
[Re: 383man]
#2226975
01/04/17 09:53 AM
01/04/17 09:53 AM
Posts: 4,573 Motor City
6PKRTSE
Motor City
I agree. I have built mine with safety coming first. It is certified to go 7.50's but I don't care if it only goes 9's or 10's at first on motor. I can keep stepping it up from there.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: EV2DEMON]
#2227043
01/04/17 01:07 PM
01/04/17 01:07 PM
Posts: 7,506 Az
Crizila
Az
So, I'm at the point where I need to figure out my goals and make a decision. Chassis work is complete (Small tire car with a 10 point CM cage). Long block is done and about ready to drop in. Motor makes 575 or so NA, I figure it'll push the car to around 10 flat as built. That would be as quick as anything I've driven.
However, I can't get past the idea of throwing an F1R on it and going for the 8 second zone. I don't hold an NHRA license, and the costs add up pretty quickly past 9.99. I could always put the car together to run NA now, and add the blower later, but then I'm changing fueling and quite a bit else.
I need you guys to sway me. For those with reasonably quick cars, is it worth it? Now's my chance to build the car the way I want, but I don't want to end up with something that's no fun due to cost and upkeep. Actually, you are a little late to be setting goals. That being said, Here is how it usually works. You start with a 12 second car. You don't break much. You can get lots of runs in. It isn't too costly. You are having fun. Then you want to go faster - more fun, bragging rights, what ever. As you step in the 11's, 10's, 9's, the costs go up ( pretty steep curve )and the # of runs you can make go down. Eventually, the cost curve ( going up ) meets the fun curve ( going down ). Forget about everyone jumping on the safety issue. Everyone has their own comfort level here, but at minimum, you have to follow the safety rules, which is just a part of the cost thing. So, my suggestion is to be realistic with your financial situation. Stick within your budget. This will help keep you in the fun range. The only other thing that may take you out of your fun range will be time behind the wheel.
Fastest 300
[Re: EV2DEMON]
#2227179
01/04/17 04:26 PM
01/04/17 04:26 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I would without a doubt put it together as is now, especially if you have all of the parts to do it.
If you’re still buying some stuff, you can always plan ahead for more power later by doing things like buying a killer fuel pump, plumbing ½” fuel lines, buying 5/8” axles/wheels, etc…
But if you already have a lot of that stuff purchased, no way would I go backwards from where you’re at.
8.50 is way more than just chassis cert type stuff.
Do you have a short block to hold 8.50 power? Do you have a trans to hold and axle that will hold 8.50 power? Are you ready to buy big dollar shocks for a 8.50 small tire car to work? Etc…
I have contemplated the same thing… mine is basically a R3 block, Crank, cam, and fuel pump away from being an 8.50 (or better) car. I just don’t see the reason to spend that kind of money to make the jump. It’s plenty fun what it runs now, and is great to drive on the street with even a 10.50 tuneup in it.
[Re: EV2DEMON]
#2227496
01/05/17 12:09 AM
01/05/17 12:09 AM
Thumperdart
State of confusion
So most of what I have is built to take the HP (Dart block, 35 spline, ect.) I don't have shocks, fuel system, and a few other components yet.
I think at this point, I'm going to put the car together to run N/A. Some of the stuff I have currently may be overkill for it, but at least I can grow into a quicker car down the road. That's what I and many others have done...........I went from 13's in my dart w/a 360 small block then stepped that up to run a best of 11.88@114 w/the usual mods. Then went 470 BB stroker w/906 heads and a .590-605 solid cam and went 10.40's but that wasn't enuff so I went W/home ported rpm's, solid roller dominator etc. 9.79 @ 135.59 @3200+ lbs. and have yet to hit a 1/4 mile since then. Last summer I went 6.15 @ 109 in the 1/8th letting off before the finish at around 3050 lbs. the whole time being a street car...........enjoy and work w/what you have and step up when you can...........
