Re: How about this bearing wear pattern?
[Re: sshemi]
#2225723
01/02/17 05:43 PM
01/02/17 05:43 PM
Posts: 4,457 Washington
madscientist
Washington
New bearings, and line hone to set the clearance.
[Re: sshemi]
#2225792
01/02/17 07:17 PM
01/02/17 07:17 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What's the crankshaft #3 main journal look like?
[Re: sshemi]
#2225864
01/02/17 09:04 PM
01/02/17 09:04 PM
Posts: 7,506 Az
Crizila
Az
Even thought lots of miles, I would still try and find the cause. Tight clearance, restricted oil passage, etc. If you can't definitively find something, for sure line bore it - and check rotational torque upon reassembly.
Fastest 300
[Re: sshemi]
#2225873
01/02/17 09:24 PM
01/02/17 09:24 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Crank is mint. Had great oil pressure. Great oil pressure wont see a {possible} restricted feed to that journal. Its not unheard of for the oil feed channels to have casting flash in them. Id run a reamer through that oil feed for sure. Along with measuring the bearing clearance on it as well. A line hone isn't a bad idea, but probably overkill, unless its going to be a race motor.
[Re: sshemi]
#2225999
01/02/17 11:59 PM
01/02/17 11:59 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Crank is mint. Had great oil pressure. Dont have new bearings yet but if my math is correct bearing clearence will be way too little with new bearings. Check it throughly and the reason for the bearing to look like that is from several factors all beeing on the same side of tolerances making clearence too small. I think/hope a linehone will fix it. is there an .001 bearing for it?What oil did you run?
[Re: Cab_Burge]
#2226060
01/03/17 12:58 AM
01/03/17 12:58 AM
Posts: 1,505 TN
SCATPACK 1
TN
I would check the center main journal for run out Even .0003 can cause that center main bearing to look like that with stock, tight bearing clearances What Cab said Exactly what I was thinking Cab. Have the center journal checked for a high spot.
Old Geezer Racing
[Re: sshemi]
#2226343
01/03/17 03:09 PM
01/03/17 03:09 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I would put a set of full groove main bearings and a set of race type rod bearings in it so they have more clearances like .0025+ on the rods and .003+ on the mains I've had several stock production early 1970s 318 motors that had the #2 main journal out of round and bent .001+ which I ended up having to use scotch brtite on that main bearing to get additional clearnces so the motor would run. Looking back now I should have used a set of 340 full groove main bearings in them Good luck on your deal
[Re: sshemi]
#2226457
01/03/17 05:53 PM
01/03/17 05:53 PM
madscientist
Washington
Rods have plenty of clearence as the rod bore is on the bigger side. Actually a bit too big. Ill check main clearence with plasti gauge. I have never used it but i feel on this i need to. Or just spend the $400 the machine shop wants to correct it all. That includes cylinder hone also. That'll be the best 400 dollars you can spend. The mains need a hone and the rods resized.
