Re: 38 hits the road pics.
[Re: Polarabill]
#222574
03/03/09 09:58 PM
03/03/09 09:58 PM
Posts: 2,833 Ontario Canada
Webster
Ontario Canada
Next question...What kind of seats and do you much room in the cab??
Beesting may have missed this question so I will answer as best I can for him.The seats are out of a Chrysler of some sort,but not sure what.Room for the driver is very limited and he is going to look into different seats.I think a low back bucket would work real well and Beesting thinks the back seat from a caravan would fit nicely.
Thanks ... I wonder if it would be tight. I had thought about Import Seats, alittle smaller, just a thought
[Re: earlymopar]
#222579
03/05/09 09:28 PM
03/05/09 09:28 PM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
In my 35 sedan, I used a pair of buckets from a ford fairmont. They were low back, thin, and narrow seats that were actually fairly comfy. Even the fairmont seats sat side by side, you had to be friends with whoever was riding with you. Tried seats from a front drive Mopar, but they were too high of a back and too wide. In my 54 pickup, I used a bench seat from a 4 door valent, it was narrow and set just under the rear window ledge. That 54 was a bit wider then the 30s cab would be, but there was still room on both sides of the valent seat, it might still fit. My 50 truck has an unknown set of buckets with the adjustable seat backs, those work out well, you set the back angle which lets you move the seat farther back. Gene
