360 Piston differences #2222930
12/29/16 07:26 PM
12/29/16 07:26 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Does anyone know the differences off hand between a 405p and H405CP speed pro pistons?
Is the only difference that the H405CP are hypers?
Re: 360 Piston differences [Re: mopowers] #2223035
12/29/16 11:25 PM
12/29/16 11:25 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
C stands for teflon coated skirt and H stands for hypereutectic.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 360 Piston differences [Re: 71yelladustr] #2223094
12/30/16 12:53 AM
12/30/16 12:53 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
Just FYI Speed pro also makes the H116CP piston which has a taller compression height and a smaller valve relief than the 405 as well. As I understand it 405's are basically a stock replacement piston giving roughly 8.0 compression, while 116's are closer to 9.5:1.
Re: 360 Piston differences [Re: mopowers] #2223151
12/30/16 02:19 AM
12/30/16 02:19 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks guys. So, are the measurements of those two the same? Same compression height? I tried calling speed pro, but they're closed this week.
Re: 360 Piston differences [Re: mopowers] #2223300
12/30/16 12:53 PM
12/30/16 12:53 PM
dogdays Offline
dogdays  Offline
He said, " the H116CP piston which has a taller compression height"
The only way to get higher compression with a piston are increasing compression height, decreasing a dish or adding a dome.
The difference between the 405P and the H405CP is the 405P is older and out of production. I'd take the newer piston any day, even though it's probably made in India. The material is better, as is the coating.
Federal Mogul sells pistons in sets. If you wanted a single piston you'd add a W to the front of the part number, such as WH116CP.
R.
Re: 360 Piston differences [Re: dogdays] #2223343
12/30/16 01:55 PM
12/30/16 01:55 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I wasn't asking about the H116 pistons. I was asking about the 405p vs the h405cp.
I understand that. That's why I was asking about differences in those two aforementioned pistons.
I finally got ahold of federal mogul. The 405P are still in production. Besides the obvious design difference (dished vs 4 valve relief) and material type and coating, the H405CP pistons have a higher compression distance than the 405P (1.637" vs the 1.576"). Thanks for your input.
Does anyone know what the dish volume of the stock pistons is? I've never measured one.
Re: 360 Piston differences [Re: mopowers] #2223499
12/30/16 06:12 PM
12/30/16 06:12 PM
I have the H405CP's & the 4 valve reliefs are 10CC & yes they are 1.637" CH
