As mentioned earlier, the actual numbers are not as important as consistency. After a while, you can adjust the practice tree closer to what you get reacting to an actual tree. But the practice does help develop a rhythm that usually translates to the real world. I've seen the difference in my consistency on the track after practicing, even though I footbrake but practice with a button!
There are places that vary from lane to lane, track to track and timing systems used as well! (Ask Beard.) Even rubber build-up and/or "crown" in the track surface can affect rollout. "You" have to get consistent and somewhat predictable first. Then you will be able to start making mechanical adjustments to the car to compensate for the changes between lanes/tracks. (and adjust the practice tree for representative RT's.) I've run anywhere from 25 lbs to 50 lbs of air in my front tires between certain tracks! Then there is always stage/launch rpm's, bumping, etc.
