3.3 INTAKE GASKET JOB #2218472
12/21/16 05:32 PM
12/21/16 05:32 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I see (or should I say "hear") the gasket's leaking. Is this a hard job? I want to do this myself if I can. I've done a couple small block intake remove/replacements. Or should I have a shop do this?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 3.3 INTAKE GASKET JOB [Re: Magnumguy] #2218484
12/21/16 05:57 PM
12/21/16 05:57 PM
Guitar Jones Offline
If you can do a small block you can do this.
Re: 3.3 INTAKE GASKET JOB [Re: Magnumguy] #2218987
12/22/16 02:26 PM
12/22/16 02:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree they are pretty easy.Just watch the bolts dont snap.Had a few at work that they were either broke or snapped.Once the intake was off there was enought to screw the broken part out.Rocky
Chrysler Firepower
Re: 3.3 INTAKE GASKET JOB [Re: Magnumguy] #2218993
12/22/16 02:34 PM
12/22/16 02:34 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Chrysler Firepower
Re: 3.3 INTAKE GASKET JOB [Re: therocks] #2219524
12/23/16 12:23 PM
12/23/16 12:23 PM
moparx Offline
moparx  Offline
sometimes a small 3/8" impact [like a "butterfly" gun] will lessen the possibility of snapping the bolts. if a bolt does snap, i would replace all just to be safe. on re-assembly, i use high temp anti seize on the threads. not a tough job at all. helps on plug changes to remove the upper plenum.
beer
