1968 B body (charger) 1/4 glass #2217453
12/20/16 01:33 AM
12/20/16 01:33 AM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
im assembling a 68 charger that someone else took apart. i need to mount the 1/4 windows in the track of the regulator. what is used to go into the holes at the bottom of the glass? what are they called, where do i get them?
Re: 1968 B body (charger) 1/4 glass [Re: mcat4321] #2218186
12/21/16 02:36 AM
12/21/16 02:36 AM
New York, USA
Chargerfan68 Offline
New York, USA
I dont know what the proper name is , but it is an insulating "grommet" (I think 2 or 3 pieces per mount hole)that a bolt goes thru to the mechanism. It protects the glass from the bolt on front and mechanism on the backside. i'll see if I have any pics from the ones I took apart.
Re: 1968 B body (charger) 1/4 glass [Re: mcat4321] #2218198
12/21/16 02:48 AM
12/21/16 02:48 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
A piece of vacuum line will work.
68 Charger R/T 440 auto
