Re: Brass freeze plug
[Re: 70duster340]
#2216511
12/18/16 08:55 PM
12/18/16 08:55 PM
Posts: 2,366 Banana Republic
FM3AAR
Banana Republic
I bought a Pioneer brand freeze plug set on a 340 I am doing, having had success with them years ago. Somewhere along the line they shortened the wall height on them to save a whole penny on the set. They don't have enough support and want to cock in the bore. Garbage. I chucked them and went with Sealed Power which has the taller original wall heights. They sit square in the bore and are tight. Also a member here gave good advice to install them by driving them in against the top of the wall edge and not insert/drive a socket against the bottom of the cup.
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
[Re: FM3AAR]
#2216551
12/18/16 09:29 PM
12/18/16 09:29 PM
RapidRobert
yes get the thick ones & I prefer permatex #1 gasket cement & put some cement on the block hole ID & the freeze plug
