Re: B&M Star Shifter [Re: Monte_Smith] #2216827
12/19/16 04:18 AM
12/19/16 04:18 AM
MR_P_BODY Offline OP
Originally Posted By Monte_Smith
Instructions say it can't be used with a reverse pattern.... if that's what you have
I read that.. but no.. standard valve body... just a
518 trans but the OD is on a switch
wave
Re: B&M Star Shifter [Re: MR_P_BODY] #2220226
12/24/16 03:49 PM
12/24/16 03:49 PM
Ohio
moparjoe360.4 Offline
Ohio
Originally Posted By MR_P_BODY
Originally Posted By moparjoe360.4
I've run the star shifter for 12+ years., first with a shift kit VB and then a forward pattern manual VB. It's got it quirks as mentioned, but as long as your paying attention you shouldn't have a problem. I personally like the two modes and the way the lock out works.I'm not sure if the bolt pattern is the same. I think you'll like the star shifter though I've never had an issue with it that wasn't operator error. up
Question for you.. do you have to lift the handle
to go into reverse or park... or do you lift the
little T handle to get into R or P thanks
wave
You have to lift the T handle to get it into reverse or park and also into ratchet mode. You don't have to do anything with the shifter handle for gear changes with this shifter. Sorry I took so long to respond. I'm glad to be able to help you, I appreciate all the help and knowledge you've shared with me when I have questions.
Re: B&M Star Shifter [Re: moparjoe360.4] #2220236
12/24/16 04:03 PM
12/24/16 04:03 PM
wave
Do you have to lift the handle when in neutral
or does it have to be in drive to get to reverse
or park.. my Qiuck Silver has to be in drive...
thats the part I'm trying to get away from.. if
its from neutral that you lift it thats fine
thanks
wave
Re: B&M Star Shifter [Re: MR_P_BODY] #2220271
12/24/16 04:56 PM
12/24/16 04:56 PM
Ohio
Ohio
thanks
wave
I just went out to the garage to verify, you can shift from neutral to reverse or park. The only time you need the t handle in drive is for a downshift or to swap from detent to ratchet modes. up
Re: B&M Star Shifter [Re: MR_P_BODY] #2220437
12/24/16 10:25 PM
12/24/16 10:25 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Ran One many years ago in My Buick..... Worked out ok for what the car was running at the time....
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: B&M Star Shifter [Re: moparjoe360.4] #2220503
12/25/16 01:31 AM
12/25/16 01:31 AM
thanks
wave
Thanks... that works for me.. I'll order it up
and some other things this coming week... I
did have a big order but I was hoping for a nice
discount code but that doesnt look to be happening
so I'll order part of what I want next week
wave
