B&M Star Shifter
#2215805
12/17/16 06:11 PM
12/17/16 06:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Does anyone run the B&M Star shifter and if so what do you think of it.. I'm looking at it for my Rampage... thanks
Re: B&M Star Shifter
[Re: StealthWedge67]
#2215881
12/17/16 08:59 PM
12/17/16 08:59 PM
MR_P_BODY
I ran one years ago. The ratchet mode is only accessible from first gear, and only goes forward two gears from there, so there are limits to what you can do with the ratchet mode. It seemed a little Mickey Mouse to me. I think it's more suited to a fully auto valve body that's just going to be in drive most of the time. Like any B&M shifter however, it offered a pretty solid feel. I'd consider it more of a "performance LOOK" shifter than a real performance piece. I now run a quicksilver and much prefer it. I have the Quick Silver in it now and I dont like it.. I hate that you have to lift the shifter when your in drive.. it wouldnt be bad if you had to lift it from neutral to get into reverse or park.. I just cant get use to lifting it in drive.. this is for a 90% street car... thanks... plus its a shorter shifter arm.. I want a shorter arm
[Re: MR_P_BODY]
#2215890
12/17/16 09:25 PM
12/17/16 09:25 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Use to have one in the Scamp, worked great. switched it out for PPP. No issues at all except burning cables but that was my fault.
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#2215892
12/17/16 09:33 PM
12/17/16 09:33 PM
MR_P_BODY
Thanks.. now I would like to see if it uses the same mounting holes.. that would save me from pulling up the carpet and welding up another mount... I do like that it has both detent and ratchet
[Re: MR_P_BODY]
#2215910
12/17/16 10:30 PM
12/17/16 10:30 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Also.. does it and the Quick Silver use the same mounts. thanks They weren't in the same car, Mike. So I can't say for sure that they are identical mounts. But I know they're very similar. If I had to bet I'd say yes.
[Re: sixpackgut]
#2215946
12/17/16 11:53 PM
12/17/16 11:53 PM
MR_P_BODY
I have the Pro Ratchet on the race car and love it but on my standard auto I want a detent shifter and that Star gives me both detent and ratchet
[Re: MR_P_BODY]
#2215947
12/18/16 12:00 AM
12/18/16 12:00 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Hi Mr.P, If you you have all the pieces I may be interested in your Quick Silver shifter. Please PM me a price if you are interested. Thinking it may be a good choice to mount under a stock console in a 65 b body.
Doug
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: 65 Hemi]
#2215949
12/18/16 12:07 AM
12/18/16 12:07 AM
MR_P_BODY
I'll keep you in mind.. yes I have it all.. its still in my car.. if I find out a bit more info on the Star and I like what they say I will order one and pull the Quick Silver.. I have 2 holes in the plastic cover for 2 switches but if you putting it in a counsel it wouldnt matter
[Re: MR_P_BODY]
#2215955
12/18/16 12:15 AM
12/18/16 12:15 AM
65 Hemi
San Diego CA
I'll keep you in mind.. yes I have it all.. its still in my car.. if I find out a bit more info on the Star and I like what they say I will order one and pull the Quick Silver.. I have 2 holes in the plastic cover for 2 switches but if you putting it in a counsel it wouldnt matter Great Thanks!
Doug
[Re: MR_P_BODY]
#2216575
12/18/16 09:47 PM
12/18/16 09:47 PM
Posts: 1,213 Minn
SportF
Minn
I wore a used one out. Put in a Mega Shifter for four disastrous passes. Took it out and bought a new Star shifter. Love it.
[Re: Monte_Smith]
#2216693
12/18/16 11:31 PM
12/18/16 11:31 PM
MR_P_BODY
Just personal opinion, but I hate "gimmicky" shifters like the Star, Quick Silver, etc. I think, but not positive that the Star and Quicksilver work exactly the same, except one you lift handle, other you pull trigger to get same functions I just cant get use to the Quick Silver.. I am always trying to lift the shifter when in neutral so I'll try the Star.. if I dont like it I'll move onto something else.. my issue is its mainly a street car but I like a ratchet when I race... I'll see how it goes
[Re: moparjoe360.4]
#2216818
12/19/16 03:30 AM
12/19/16 03:30 AM
MR_P_BODY
I've run the star shifter for 12+ years., first with a shift kit VB and then a forward pattern manual VB. It's got it quirks as mentioned, but as long as your paying attention you shouldn't have a problem. I personally like the two modes and the way the lock out works.I'm not sure if the bolt pattern is the same. I think you'll like the star shifter though I've never had an issue with it that wasn't operator error. Question for you.. do you have to lift the handle to go into reverse or park... or do you lift the little T handle to get into R or P thanks
