Auto for Autocross? #2215290
12/16/16 08:37 PM
12/16/16 08:37 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
What about running an 727 or a 518 or so with a 650Hp Big Block in Autocross?
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Auto for Autocross? [Re: Bob J] #2215292
12/16/16 08:39 PM
12/16/16 08:39 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Auto for Autocross? [Re: amxautox] #2215305
12/16/16 09:14 PM
12/16/16 09:14 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
Originally Posted By amxautox
Thank you and I read that before dam I must be getting old or something. What about a converter I would think that it should be tight as you wouldn't want it to flash coming out of the turn.
Also with a 1.57 second gear installed with a 3.73 gear and 25.5 dig. tire that is 77 MPH at 6k. The perfect setup gets you to 62 - 65 MPH in second. A 1.92 second gets you there like a 18 spline 4 speed. I guess with over 625 HP and 580 TQ. I may not worry about pulling a 1.57 second gear.
Re: Auto for Autocross? [Re: Bob J] #2215313
12/16/16 09:32 PM
12/16/16 09:32 PM
amxautox Offline
amxautox  Offline
Just be sure the torque comes in at a lower rpm, maybe by advancing the cam 3 degrees or so, and you won't have anything to worry about and won't have to buzz the engine.
Tom
author unknown
Re: Auto for Autocross? [Re: Bob J] #2215329
12/16/16 10:06 PM
12/16/16 10:06 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
236, 244 at 50 duration on a 113 center and 114 lode separation and only 533, 540 lift with a 1.6 rocker and 493 stroker it starts low on the TQ.
Re: Auto for Autocross? [Re: Bob J] #2215331
12/16/16 10:08 PM
12/16/16 10:08 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
Oh and it's a Hydraulic roller and will have Fuel injection.
Re: Auto for Autocross? [Re: Bob J] #2215339
12/16/16 10:20 PM
12/16/16 10:20 PM
amxautox Offline
amxautox  Offline
Sounds like it'll do great at low rpm, and will move the car just fine in 2nd at a low rpm. My car does great, almost stopped and in second and it'll move along just about as good as in 1st. But then AMC engines are known for their low rpm torque.
Tom
author unknown
Re: Auto for Autocross? [Re: Bob J] #2215398
12/16/16 11:57 PM
12/16/16 11:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A stock 318 is enough to get the novice driver in over thier heads fairly easy, just sayin, before you quickly discover putting down 650hp with a big block is rather difficult, but driving it like a go kart (left foot braking) is fun. up
Re: Auto for Autocross? [Re: jcc] #2215471
12/17/16 02:43 AM
12/17/16 02:43 AM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
I have been running a Porsche 911 in super street for years now. I have been looking to upgrade to a 997 GTS or a 997 GT3 but they just let the 991 GT3 in the class. I also looked at a 08 Boxster RS60 Spyder for BS or taking my car to ASP with Hoosiers, but this is my daily driver and that would take mt 911 out of daily use with camber plates high spring rates and -3.5 deg of camber. Plus I need a trailer. This project has been stalled since I started racing the Porsche's. Hell I bought the engine parts in 06 with the Wilwoods so I just want my big block power back. Anyway here in Colorado I will be only at around 550 Hp. The last 10 years is the first time I haven't had a built big block since the late 70's.
Buy the way I'm a SCCA SOLO safety steward so I'm not a novice. I'm just looking to finish a long over do project car and have a blast driver to the limit OK and past the limit and to kill a few more cones. This is what I have been running from a few years ago at a Match Tour.
Re: Auto for Autocross? [Re: Bob J] #2215476
12/17/16 02:48 AM
12/17/16 02:48 AM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
This is what I'm working on now.
Re: Auto for Autocross? [Re: Bob J] #2215477
12/17/16 02:50 AM
12/17/16 02:50 AM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
Plus
Re: Auto for Autocross? [Re: Bob J] #2215482
12/17/16 02:57 AM
12/17/16 02:57 AM
amxautox Offline
amxautox  Offline
Looks like a fun car.
Here's my car before and after paint.
Tom
author unknown
Re: Auto for Autocross? [Re: Bob J] #2215618
12/17/16 01:41 PM
12/17/16 01:41 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
I always love the Mark Donahue paint jobs that they had. I lived in Kenosha in 70. My first car was a 71 Javelin that I got from my Dad in 73.
Re: Auto for Autocross? [Re: Bob J] #2215625
12/17/16 01:50 PM
12/17/16 01:50 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
I always love the Mark Donahue paint jobs that they had. I lived in Kenosha in 70 so I saw a lot of those cars. My first car was a 71 Javelin that I got from my Dad in 73. It looks like you were running ESP are you running CAM T or C now? CAM looks like a fun class and the folks are a let us help you get faster.
Re: Auto for Autocross? [Re: Bob J] #2215676
12/17/16 02:59 PM
12/17/16 02:59 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
You will probably want to have a custom converter done with that type of usage in mind. Thats what I did for my car as auto cross is one of the main things I have planned for it plus some trips to the drags. I had mine done by Continental. Gave them the engine dyno sheet, specs, car weight, gearing, tire size, trans specs, useage etc.
Carl Kessel
Re: Auto for Autocross? [Re: Bob J] #2215683
12/17/16 03:11 PM
12/17/16 03:11 PM
amxautox Offline
amxautox  Offline
I haven't run autocross since about 2001. Been spending all my time Bass fishing.
Tom
author unknown
Re: Auto for Autocross? [Re: CKessel] #2215702
12/17/16 03:30 PM
12/17/16 03:30 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
Yep custom converter I was talking with SMR yesterday on a 727 and converter for what I'm doing. It needs to live with 700 HP encase I change the cam for more power but I'm going to see how this motor does first.I was looking at Passon 5 speed but that is a year out and $5200. I could also go with Passon 4 speed overdrive with a 1.77 second or just buy a 18 spine 4 speed with a 1.92 second. I'm just looking at my options. I will be running 2 set of wheels 1 for racing and 1 for street driving. The race tires will be BFGoodrich Rival S 275 X 35 x 18 Fr and 315 x 30 x 18 rear. That is a 25.5 tall tire and I want to be around 65 mph in second. I'm also shooting for around 3400 to 3500 lbs car but that is a long shot.
Re: Auto for Autocross? [Re: amxautox] #2215703
12/17/16 03:32 PM
12/17/16 03:32 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
I'm not sure I can slow down that much yet.
Re: Auto for Autocross? [Re: Bob J] #2215706
12/17/16 03:37 PM
12/17/16 03:37 PM
amxautox Offline
amxautox  Offline
I've thought about starting up again, but couldn't afford to, then 2 years ago bought a new boat, so still can't afford to. laugh2 Haven't even driven either car for 2 years.
Tom
author unknown
Re: Auto for Autocross? [Re: Bob J] #2215795
12/17/16 05:50 PM
12/17/16 05:50 PM
omahell, ne
buconine Offline
buconine  Offline
omahell, ne
It will be great to have anther mopar at the races! The Chenowths and I are the lone mopars at nats the last couple years.
Shooting to have my cam-t valiant ready by spring but that is a long shot as i just took on another major project. It will be a 500hpish rb with a 727. I had some of the same concerns with the auto but i think i will be fine. I'm running a 275 35 18 square with a 323 gear. Our average course speed is 40-45mph with peaks of 68-70 mph on the really fast courses. That will stick me in 1st for most of the courses with the occasional blip into 2nd.
Can't wait to get this thing done. My 15 scat pack is fun but just isn't competitive nationally. Hoping the valiant does better. Good luck on your build!
