360 piston dish #221300
02/11/09 06:00 PM
02/11/09 06:00 PM
West Tennessee
rbstroker Offline OP
West Tennessee
Does anybody have the spec for the volume in cc's for the piston dish on a 1979 360 2bbl?
Re: 360 piston dish [Re: rbstroker] #221301
02/11/09 06:10 PM
02/11/09 06:10 PM
8CC
Re: 360 piston dish [Re: rbstroker] #221302
02/12/09 01:43 AM
02/12/09 01:43 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Here is the 360 specs I have for the silvolite cast replacement pistons:
Dished Piston #SL-1279 Compression Height = 1.576", Dish = 7.5cc
Flat Top Piston #SL-1273 Comp Height = 1.576", 0cc dish/dome (Flat Top)
With a 9.60" Deck the pistons should be 0.111" below the deck at TDC.
Re: 360 piston dish [Re: 451Mopar] #221303
02/12/09 01:50 AM
02/12/09 01:50 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Wanna send out a search party?? Thats Waaaay down there...
Re: 360 piston dish [Re: 1_WILD_RT] #221304
02/12/09 02:25 AM
02/12/09 02:25 AM
My Badger 360 flattops(#B290's) have the same CH(1.576") & a measured .110" in the hole
Re: 360 piston dish [Re: RapidRobert] #221305
02/12/09 07:53 PM
02/12/09 07:53 PM
West Tennessee
West Tennessee
Picked up the 360 from a Moparts member. Just finished measuring everything. The stock pistons are .088 in the hole. The heads cc'd at 67 average. Plugging in the 7.5cc dish and a felpro 8.9cc head gasket yields 8.37 compression ratio which is just shy of the advertized 8.4. If I mill .072 from the heads, it yields 52cc chambers which amounts to 9.48 compression ratio. Can I safely do this or will the fact that there will be no quench mess things up. This is a really low budget bracket car for my grandson.
This is the land of the free because of the brave
Re: 360 piston dish [Re: rbstroker] #221306
02/12/09 09:00 PM
02/12/09 09:00 PM
IN
ahy Offline
ahy  Offline
IN
As "rule of thumb" 9.5 is considered max for non quench pump premium. CR should be OK, especially if its getting a more aggressive cam. I don't know if its considered safe to take that much off those particular heads though. Shorter pushrods and manifold milling may be required.
Re: 360 piston dish [Re: ahy] #221307
02/12/09 10:09 PM
02/12/09 10:09 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
I am working on a friends '75 360.The stock pistons were .082 down in the hole.That was measured on the rim of the piston.
